Results 1 to 5 of 5
- Nov 2008
- 5
November 18th, 2008 01:47 PM #1mga sir ask ko lang po, pag nag shift po kasi ako sa 1st gear yung engine nag vi-vibrate with some knocking sounds na parang mamamatay makina, so shift ako 2nd gear ok naman hanggang fifth, 1st gear lang talaga. suspect ko na po na sa tranny ang problema pero di ko lang po alam kung ano talaga dun ang may kelangan palitan or may problem. is it the clutch or pressure plate, etc.
ano po kaya sa tingin niyo ang problem? TIA
November 25th, 2008 09:53 AM #2
Have your clutch checked by a mechanic...
__________________
bigbigcar.com Review: Chery QQ3 1.1 MT
Small car, big ambitions: The Chery QQ is the vanguard of the Chinese invasion.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 30th, 2008 04:12 PM #3engine supports yung likely na problem but you'll need to have them checked in person by a mechanic.
- Jan 2005
- 445
December 18th, 2008 12:45 AM #4I bet its either a dragging clutch or a sliding clutch. P baba mo na tranny mo, palit clutch, pressure plate and release bearing.
Kung engine mount yan pag nag low gear ka mula sa mataas, mararamdaman mo vibration at hindi kaya patayin ang makina ng engine mount problem.
- Nov 2006
- 299
We previously supported Tapatalk for Google Play and iOS store, but both are unsupported right now....
tapatalk smart phone application.
