Page 1 of 3 123 LastLast
Results 1 to 20 of 60
    Oct 2008
    Are you in favor of this security bolt?
    Looks OK para iwas sa baklas ng plaka.
    Ano naman ang disadvantages?
    May 2015
    Pinakita sa tv kanina (can't really remember the name of the program pero si Jessica Soho yung host) na kinabit nila sa motorcycle yung plate with the new bolts and wala pa 1 minute nakaya din tanggalin nung mekaniko yung screws. I don't know with cars pero from what I've read kapag ipapagawa mo front and back ng car magkaka problema ka in terms of the plates and boltssss.
    Quote Originally Posted by yellybeans View Post
    this is how i would do it if i wanted the plate removed "clean"
    use dremel wireless to create a line,
    use flat head screw driver to unscrew the bolt.
    It's because kayang abutin yun likod ng screw Sa motorcycle but hinde naman maabot pag kotse.
    Aug 2009
    Ano po kaya mangyayari if we are in need to repair the portion having the plates, hingi pa permit lto for it and as usual pay na naman. And since nabaklas na ung issued bolt and nut nila, request pa ba and pay again for the replacement?
    Jan 2009
    Removing them is the easy part. Getting caught not using them is the real downer. http://www.topgear.com.ph/news/motor...es-do-the-same
    Mar 2004
    LTO personnel admits that the supplied bolts won't fit all vehicles and they themselves don't follow the rule.
    http://www.topgear.com.ph/news/motor...ame?ref=latest
    ewan ko talaga sa lto
    G*go talaga ang mga g*gong taga LTO. Ginag*go pa tayo.
    Will LTO sell their sacred security bolts?
    And I think they should!
    So if one needs to remove their plates by destroying the old sacred bolts, no need to buy new plates. No need to be worried of being apprehended for using non-prescribed bolts.
    Bro yung security bolt kaya gawin sa machine shop. Unless readily available sya sa LTO, mahirap kasi umasa sa kanila sa ganyan.
    Sabagay dami fabricators, hopefully magkaron nga ng available para hindi na maging issue talaga.
    Weird thing hindi pala fit to all vehicles hehe epic failure nanaman.
    Nagbalak din ako pa fabricate ng screw, mas mahaba ng konti sa lto. Kaso nung kumasya, ok na ako
    Screw them!!!!! :hammer:
    Yan na nga ba sinasabi ko nang una kong makita yun bolts nila nung kinuha ko yun plaka ng Mazda 3 ko sa dealer eh. Ang iksi sobra na hindi man lang ata aabot hanggang doon sa dulo ng turnilyuhan ng bumper ko. Eh threadless pa naman yun bumper so needed ng nut para lang ma-screw. Ayun di ko nalang ginamit at yung binili kong 1.5" na allen bolt ang ginamit ko. Sa 1.5" na bolt na yun, mga 1/4" lang ang lumitaw sa dulo, which is enough para ma-tighten ng nut.
    Mar 2004
    Wait a few more months and the screw will be available at hardware stores.
    Baka available na sa alibaba
    Has there been any known apprehension for those who did not use the LTO security bolts? I've seen many (mostly plate replacements) already not using these bolts. Some even still using their clear plate protectors.
    ^^^bago sa screw ing butas na lang ng plaka, sablay kahit sa lumang civic ko di pasok ung sa likod, sa officemates ko na ford and fiesta di din pasok sa likod, nagdrill ng hole.
    Tengeneng LTO to - Lokoloko Trantado Ogag
    Jan 2014
    I thought sabi ng LTO may security itong Bolt na ito correctt me if I'm wrong, kasi kanina around 12nn may nakita akong Eon nakadikit sa plate holder niya Lost plate AAK pa umpisa eh
    Jun 2015
    correct ka dyan
Security Bolts on Plates
