Results 21 to 30 of 44
March 20th, 2007 02:47 PM #23
everything pretty much has been covered. i just want to add not to take the actual exam at the DMVs located in big cities. things like parallel parking aren't included in the test if you take it at a small town. also, go to the DMV where you'll be taking the test and follow (not stalk
) the test cars. this will give you an idea where the test routes are, which will help you on your preparation. good luck!
March 20th, 2007 03:12 PM #24
March 20th, 2007 03:34 PM #25
mga sir, ehh pano ang procedure ng pagkuha ng CA license kung meron ka nang out of state license? may roadtest pa ba?
March 20th, 2007 03:38 PM #26
March 20th, 2007 06:50 PM #27
why don't they want the ss cards unlaminated anyway? what's wrong if you laminate it???
*redorange :
how do they check if you have a DL?
Tsikot Member Rank 4
- Jun 2006
- 1,046
March 21st, 2007 01:54 AM #29everything has been pretty much mentioned, but i'd like to add one important thing. as soon as you get in the car when you take your actual driving exam, first thing you must do is to buckle up. do not insert the car key or start the car unless your seatbelt is buckled up. pag pinoy ang magbibigay ng test, automatic fail ka na. yung ibang lahi magde-deduct lang ng points.
isa pa pala, when parallel parking avoid touching the curb. this is an automatic F.
Yes, because 100 degree boiling point is measured at sea level. What's interesting also is that...
