Results 1 to 10 of 44
- Jan 2003
- 611
March 19th, 2007 06:22 PM #1Anyone from CA here? I wish to get a CA DL tomorrow. Both written and actual exams are required. Any tips you may wanna share to easily pass the exams?
Tsikot Member Rank 4
- Jan 2003
- 1,403
March 19th, 2007 06:45 PM #2http://www.dmv.ca.gov/dl/dl_wt.htm
There is a on-line tutorial.
Good luck!
March 19th, 2007 06:47 PM #3
bro goodluck kayang kaya mo yan...marami ata yung mga traffic signs..saka sa actual driving relax lang at basta me stop sign full stop ka lang..pag nag park naman reverse tingin ka sa likod...k ingatz bro
- Jan 2006
- 9
March 19th, 2007 07:35 PM #4Make sure to read the reviewer brochure of CA. Some of the questions are base on BAC, DUI, DWI which differs from states to states, also position of back and front tire when parking on downward and upward street, speed limit residential, commercial, school zone, when to used a low and high beam light, street/highway signs and so forth. Spend some time to review/read the test book brochure and you'll surely pass the written test...
Goodluck..
March 19th, 2007 08:41 PM #5
Make sure your car is working properly too, di pwedeng may kulang. Check nila yan. Also make sure exaggerate ka gumalaw kunyari tingin ka sa kaliwa when changing lanes, talagang tingin ka hindi lang lingon. May kasamang twist ng torso. Same with backing up talikod ka dapat di pwedeng sa rear view mirror ka lang titingin.
- Nov 2005
- 368
March 19th, 2007 08:49 PM #6be aware of the signage: No turn on red... karamihan ng kilala ko diyan nadadale...
Goodluck!!
March 19th, 2007 09:11 PM #7
Sa stop signs, full stop before the line..then crawl, stop again until you see the traffic, proceed when clear. Pag walang line, the actual STOP sign is your imaginary line.
Tama sila when changing lanes, kailangan mo talagang lumingon.
Cyempre sa residential strictly 25 lang unless may sign na 15. On 35 and 45 highways, never ever go 36 or 46 and beyond. If you can keep it * 35 or 45 exactly the better.
Pag may narinig kang wang wang (ambulance, police, fire truck), the examiner will not tell you to pull over. You HAVE to pull over sa side.
Hands on steering * 10-2 position.
March 19th, 2007 09:16 PM #8
When you're looking around to see if it's clear, exaggerate the turn of your head. Lean forward if you have to. Don't depend on looking around with eyes only. Those little things are what caused my wife to fail an otherwise excellent driving test on her first attempt at a driver's license.
March 19th, 2007 09:23 PM #9
When changing lane,- after you visually verify that the lane is free,- make sure that you change lane fast (do not swerve though).... Do not change lane 2x at once.....
When merging with the traffic,- make sure that your speed matches the main traffic's speed. As much as possible, do not exceed the speed limit....
just4u,- have not seen any traffic sign "No right turn on red signal" (at least in the Silicon Valley area),- always turn right with caution though....
If there is no traffic signal light for left turn,- turn left with caution on green light only.
2201:attack:
Cooling system is sealed so atmospheric pressure shouldn't be affecting internal pressure. But...
