Results 1 to 4 of 4
February 20th, 2007 01:36 AM #1
meron po ba problema (such as wheel well or shock purch rubbing) kung tires gamitin ko is 205/45, or 215/40?
car's stock, not lowered.
if so, what tire size do you recommend?
thanx in advance.
February 20th, 2007 01:54 AM #2
205's work even on a stock body corolla with lowering, as long as you roll the fenders and have the right offset for your rims. kung widebody ang auto mo you have the option of getting much wider rubber. 215's are definitely an option, and you might even go wider in the back - basta tama yung offset, and the fenders rolled and flared to accommodate.
just try a few sizes and see which size looks almost flush to the fender lip with the rims you are planning to use....
April 17th, 2007 11:37 PM #3
April 21st, 2007 05:44 PM #4
Pwede yan bro, lalo na hindi naman naka drop. Not sure kung kailangan pukpukin or i-grind yung fenders kung hindi naman naka drop.
Just had a chat with a friend in upper management of Nissan Phil. They are releasing two new...
2025 Nissan Kicks
