Results 1 to 10 of 11
October 21st, 2015 10:11 AM #1
corolla GLI 1995 model
ano kaya yung sound na yun ok naman gear oil. any treatement o conditioner na pwedeng ilagay sa transmission
October 21st, 2015 01:43 PM #2
For manual transaxle:
Gear lubricant 5 (85W140). Check your front wheel bearings and CV joints, check your brakesLast edited by jick.cejoco; October 21st, 2015 at 01:52 PM.
October 21st, 2015 01:55 PM #3
tuwing kelan lumalabas ang ingay?
accel, cruising o deceleration? or at idle?
or
sa anong gear position? 1st, 2nd, etc?
or
clutch pressed or not?
or
kapag kumakabig sa kanan o kaliwa? or straight ahead?
October 21st, 2015 01:55 PM #4
or
or
or
October 21st, 2015 02:55 PM #5
October 21st, 2015 03:12 PM #6
Check your wheel bearings and front wheel hubs for this noise while under load( weight of the car on the tires)
If you have antilock brakes, this is confirmed by a noisy signal of the wheel speed sensor on an oscilloscopeLast edited by jick.cejoco; October 21st, 2015 at 03:14 PM.
- Nov 2008
- 641
October 22nd, 2015 10:27 AM #7If its confirmed that its within the transmission, pull it down and have the bearings checked. Happened to my Revo before. While I was on my 4th to 5th gear, every time I press the gas, I hear a somewhat whining sound. Kung minsan dinig ko parang may motor na sumosunod sa akin
. Nung binuksan, nakita yung dalawang bearings connected dun sa final gear na worn-out na pala. Replaced the bearings as well as the gear oil. Now its super quiet already
- Nov 2008
- 641
October 22nd, 2015 10:27 AM #8If its confirmed that its within the transmission, pull it down and have the bearings checked. Happened to my Revo before. While I was on my 4th to 5th gear, every time I press the gas, I hear a somewhat whining sound. Kung minsan dinig ko parang may motor na sumosunod sa akin
October 22nd, 2015 11:27 AM #9
- Nov 2008
- 641
October 22nd, 2015 04:05 PM #10Yung sa Revo ko If I remember it right, mga nasa 4 to 5k yata lahat, kasama na dun bearings, gear oil and labor. Worth it na din kasi ibang iba yung feel nya ngayon, hindi na disturbing
Good luck!
Hindi na cover sa warranty dahil lubog sa baha. Nahirapan siyang i claim sa insurance dun sa...
China cars
