Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    Jul 2003
    corolla GLI 1995 model
    ano kaya yung sound na yun ok naman gear oil. any treatement o conditioner na pwedeng ilagay sa transmission
    Feb 2009
    For manual transaxle:
    Gear lubricant 5 (85W140). Check your front wheel bearings and CV joints, check your brakes
    May 2009
    tuwing kelan lumalabas ang ingay?
    accel, cruising o deceleration? or at idle?
    or
    sa anong gear position? 1st, 2nd, etc?
    or
    clutch pressed or not?
    or
    kapag kumakabig sa kanan o kaliwa? or straight ahead?
    May 2009
    or
    or
    or
    Jul 2003
    Quote Originally Posted by miked View Post
    or
    or
    or
    habang tumatakbo sa highway naka accelerate pero pag bitawan ko acceleration wala naman
    Feb 2009
    Check your wheel bearings and front wheel hubs for this noise while under load( weight of the car on the tires)
    If you have antilock brakes, this is confirmed by a noisy signal of the wheel speed sensor on an oscilloscope
    Quote Originally Posted by acenie View Post
    If its confirmed that its within the transmission, pull it down and have the bearings checked. Happened to my Revo before. While I was on my 4th to 5th gear, every time I press the gas, I hear a somewhat whining sound. Kung minsan dinig ko parang may motor na sumosunod sa akin . Nung binuksan, nakita yung dalawang bearings connected dun sa final gear na worn-out na pala. Replaced the bearings as well as the gear oil. Now its super quiet already
    Jul 2003
    Quote Originally Posted by jvnj View Post
    salamat sa lahat. transmission din ang sabi ng mekaniko ko mahal kaya bearings?
    Yung sa Revo ko If I remember it right, mga nasa 4 to 5k yata lahat, kasama na dun bearings, gear oil and labor. Worth it na din kasi ibang iba yung feel nya ngayon, hindi na disturbing Good luck!
wheening sound sa transmission
