Results 11 to 20 of 20
December 25th, 2014 07:43 PM #11
Worst would have been a leaky brake hydrovac and sticky rear drum brakes (mine is an earlier model). Local and later models used a more reliable all disc set up.
December 26th, 2014 10:29 AM #12
December 27th, 2014 10:02 PM #13
1. Kalawang (area between the firewall and hood/wipers/front windshield and doors).
2. Turbo (no leaks and functioning properly)
3. Clutch (kung m/t) as the torquey engine can kill the clutch if driven with a not so smooth clutch foot.
4. Brakes; in the m/t version, the engine does a lot of engine braking so you don't notice right away if the brakes are weak or not (this is the problem on our LC80 now... i think the hydrovac needs to be checked).
FC on the m/t is around 6-7km/l city driving. I rarely check the FC on ours since it's a family car (family heirloom actually) so there are three of us who use it from time to time.
Check also that the mileage is not spun. I see some used LCs on the market with mileages that appear to be dubious. Although i don't mind if it's high mileage, what's important is that you know what needs to be done to ensure the vehicle is properly maintained and those who spin the mileage negate that since you don't know the actual km reading so you'll be forced to do a general service just to be sure (change all fluids, filters, t-belt, water pump, etc.).
We're already planning to have ours restored since the body is in bad shape. Mechanically, it's running great save for the weak brakes, after almost 20 years so it's high time to do a body repair before rust eats it up (we took delivery of our local LC80 in December 1995, brand new).Last edited by vinj; December 27th, 2014 at 10:05 PM.
December 27th, 2014 10:15 PM #14
Make sure it is a local version not converted
US version are mostly V8 so keep away from them
we have a 1992 us ver. and it is truly a gas guzzler
get the stock one
If you are eyeing the diesel one
make sure it is maintained properly
I see a lot of lc80 belching black smoke
Pakinggan mo yung engine or gamitan mo ng stethoscope
check mo yung tire thread
check mo yung ODO baka tampered
Test drive the vehicle
and feel how it drives and check the suspension baka may kalampag
check the brakes(ours has weak brakes already)
That suv is a perfecr off-road companion
December 27th, 2014 10:20 PM #15
December 27th, 2014 10:41 PM #16
^ The US versions had a straight six. The V8s only came out in the 100 series.
The 4WD shifter on the m/t versions are on the upper right side of the center and the 5-speed is angled towards the driver.
January 3rd, 2015 08:58 PM #18
Thanks for the inputs mga sir pero mukhang papass muna kami sa LC80. Ayaw na ng father namin kumuha ng second hand.
- Jan 2015
- 1
January 4th, 2015 10:29 AM #19Hi otep could i onow the address of 112lc house and dr g's cannot find it in google only shows qc thank you
January 30th, 2015 11:37 PM #20
Dr. G. Is in selecta drive q.c. Near a. Bonifacio and araneta avenue. Never been to 112. I transact with 112 via Dr. G's since they are friends.
Xiaomi E-Car
