Results 1 to 8 of 8
- May 2013
- 2
May 11th, 2013 09:28 PM #1I accidentally put the positive battery cable to the negative and the negative to the positive in my Toyota Vios 1.5G. I changed all busted fuses, but it still won't start. Is it true that the computer box was damaged?
May 11th, 2013 09:48 PM #2
Bro check mo yun positive battery terminal meron parang fuse yan baka naputol.
- May 2013
- 2
May 12th, 2013 10:34 PM #3
- Sep 2014
- 1
September 3rd, 2014 04:24 PM #5Experienced similar problem here. Our landlord helped me jumpstart the dead battery of my VIOS 1.3E (already due for replacement), but I think he made a mistake by putting the positive end on the negative and vice versa. When that happened, there was a spark, and it triggered the car alarm. Our landlord immediately switched the position of the cables. I tried to start the car, the engine ran, but as I tried to drive it, the car stopped running. The car won't start, the lights won't work, no aircon, no auto-lock. So I just decided to buy a new battery and see if it will solve those issues.
After I replaced the battery and waited for about an hour (I was advised to do that to reset system), the car won't still start. I asked around and people said the computer box is broken.
Is it true? Or is there any possibility that the issue was caused by other things? I really need help because I found out that a new computer box is very expensive.
- Feb 2011
- 129
September 3rd, 2014 05:59 PM #6
- Sep 2008
- 142
- Sep 2008
- 142
September 8th, 2014 11:48 AM #8
Iba naman nang yari sa amin, may tumirik na taxi car sa harapan namin, d ma start ng driver ksi due for replacement na baterry nyla. tinanggal ku baterry ku at nilipat nmin sa car nya para umandar. ok na car nya na umaandar. cya nagbalik ng baterry ku sa car ku, said his thank you and went off.
In few minutes ng paandarin ku na car nmin, ayaw umaandar not until napalitan na yung fuse ksi napagbaliktad pla nya paglagay ng baterry. buti mura lng fuse hehehe!
