Results 21 to 30 of 31
- Nov 2002
- 117
November 27th, 2006 12:02 PM #21ARB,
I heard merong OME shocks specifically developed for the REVO. Is this accurate? So the valving of which is most suitable to the weight/design of the REVO suspension, hence, will end up performing better compared to other shocks (that may have been designed for a different vehicle/type). Did I get your right?
BlackVX, you got PM.
Thanks.
November 27th, 2006 07:15 PM #22
yes there are OME shocks for the Revo. The choice of what brand depends, each brand has its own advantages and disadvantages.
- Nov 2002
- 117
January 2nd, 2007 02:27 PM #23I changed my shocks to RANCHOS...malaki ang improvement sa handling at stability ng ride. I also noticed that the 'tagtag' factor has been reduced, and the body swaying has been controlled.
I put RS5000 in front, and RS9000 at the rear. I'm riding on #2 setting (rear). Great ride and control.
The expense is worth the additional driving pleasure and comfort.
Thanks for BlackVX and ARB for your inputs.
- Aug 2003
- 107
September 10th, 2009 07:45 PM #24sir buhayin ko lang po etong thread na eto...
magkano po ba yang rancho shocks na yan at saan po pwede mag inquire, thanks
- Aug 2009
- 16
September 11th, 2009 08:44 AM #25
- Aug 2003
- 107
September 11th, 2009 12:17 PM #26oo nga boss sobrang ako din gusto ko mag palit ng shock na rancho please update us....
ok ba talagang baligtarin yung isang leaf springs sa likod then palit nitong rancho shock?
any shop?
October 7th, 2009 02:48 AM #27
jevy parang flat na rin yata yung lower leaf spring ng revo natin kaya para useless ibaliktad..
pero sa rancho 9000, balitaan mo ako at baka i-try ko sa december pag-uwi ko sa pinas hehe..
October 7th, 2009 03:36 AM #28
is it the last leaf of the spring or the 2nd leaf from the bottom which is to be inverted?
sir dom parang flat nga yata yung last na leaf sa spring ng revo...
October 28th, 2009 04:26 AM #29
October 28th, 2009 06:19 PM #30
Thread was made nung 2018 pa po sir.
