Results 1 to 9 of 9
- Mar 2012
- 10
May 18th, 2012 09:43 AM #1Ask ko lang po kung ano ano po ba ang dapat ko palitan pag nagpatune-up ako. Toyota Corolla XL big body po ang kotse ko. tune-up ko na po kasi sa sunday.
Pakilagay na lang po brand or model:
1. Oil?
2. Oil Filter?
3. Sparkplug?
Salamat po ng marami.
May 18th, 2012 10:05 AM #2
sa tune-up, usually ang pinapalitan ay spark plugs, air filter (kung marumi na talaga) and fuel filter.
yung engine oil and oil filter ay kapag magpapa-change oil, pwede naman isabay na rin yan sa sunday.
alternator and aircon belts, depende sa findings ng mechanic this sunday, baka wornout na rin.
ordinary mineral oil = change oil every 5,000 kms.Last edited by zero; May 18th, 2012 at 10:10 AM.
- Mar 2012
- 10
May 18th, 2012 06:34 PM #3Hala lagot Castrol fully synthetic po nakalagay ngayon sa engine ko. Pwede po ba this Sunday pag nagpachange-oil po ako mineral nalang ipapalagay ko wala po bang masamang effect sa makina yon?
May 18th, 2012 07:27 PM #4
You can use fully synthetic motor oil with no issues. Just that you have spent twice or three times the cost of regular motor oil.
Waste of money for an ordinary engine.
- Mar 2012
- 10
May 18th, 2012 09:21 PM #5
May 18th, 2012 10:59 PM #6
1. Oil? mobil oils
2. Oil Filter? Denso 90915-YZZC5 made in japan
3. Sparkplug? NGK platinum or iridium
- Jun 2011
- 48
May 19th, 2012 02:54 PM #7I guess yung car mo ay ito yung modelo na mayron pang carburador? hindi pa ito yong mayron fuel injector.
Sa tune-up, kelangan 1) i-adjust ang spark plug gap at itama sa specs. Kung bago pa spark plug mo huwag mo muna palitan. Spark plug pinapalitan after mga 2 years. 2) Contact point nililinis din at ini-adjust sa correct gap. Kung mga 2 years na siya, pwede na rin palitan ang contact point kasama ang condenser. 3) Ignition timing ay chinicheck din at inilalagay sa tama kung ito ay wala na sa tamang timing. 4) Ang carburador ay iniaadjust din ang idle air-fuel mixture para matipid. at inilalagay sa tama ang idling rpm (mga 700 to 800rpm). 5) check din at adjust kung kailangan ang valve clearance sa intake at exhaust valve. 6) Ang change oil at change filter ay ginagawa after 5000 km or 3 months (kung ang oil mo ay regular grade) o after 10,000km or 6 months kung ang langis na nakalagay ngayon sa makina ay premium grade. mga premium grade na langis sa ngayon ay mga API SL or API SM ang nakamarka whether mineral based oil or synthetic. Ang air filter ay patignan mo na rin sa mechanik. kung marumi pwede bugahan ng hangin para maalis ang dust. pasilip mo na rin ang fuel filter kung marumi na pwede na rin palitan. Ang mga fan belts madali lang makita kung kelangan ng palitan.
I hope nakatulong ako sa iyo.
May 20th, 2012 05:58 PM #8
I use Petron Extra for the oil of my Corolla XE and NGK for its sparkplugs.
- Mar 2012
- 10
May 21st, 2012 10:13 AM #9Mga Sir maraming salamat po sa mga impormasyon na binigay nyo. Malaking tulong po ito para sa isang katulad ko na walang pang alam sa maintenance ng kotse. Hindi po natuloy ang tune-up ko kahapon. Sabi ng mekaniko sa Sabado na lang daw po.
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
