View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 373 of 385 FirstFirst ... 273323363369370371372373374375376377383 ... LastLast
Results 7,441 to 7,460 of 11582
    Jan 2014
    Guys, need your help. After 10km mileage i stay away from.casa for my pms. Now its already 40km, aside from change oil what else do i need to change for my vios?
    Sent from my SM-G930F using Tapatalk
    Jul 2014
    Quote Originally Posted by akosidab View Post
    Coolant, gear oil including drain and fill plugs gaskets, brake fluid, spark plugs.
    Sent from my SM-G7102 using Tapatalk
    Sep 2011
    newbie here and I'm certain this was asked previously a few times.
    how much is usually the costs for first 1,000 km? salamat.
    Nov 2018
    Quote Originally Posted by loathing View Post
    Newbie here! 2.5 or 3k ata nagastos ko sa 1st PMS. Fully synthetic oil lang tapos pinatanggal ko lahat ng extra.
    Feb 2019
    Around 2.5k dahil free yung labor. Half-synthetic lang nilagay ko.
    Jan 2019
    Hello sa lahat! Do you know the part number of the cabin air filter of 2010 Toyota Vios 1.3E. Because ours did not have one. Napansin ko kasi na parang mahina na ang buga ng aircon. When I looked behind the glovebox compartment to check baka madumi lang yung filter, I discovered na wala palang filter! Pls share naman, sa mga nakakaalam. And how much po kung bilhin sa casa? Thanks in advance 8-)
    Jan 2017
    Question, ok ba ang size 17 sa vios 2nd gen. Planning to change to aftermarket mags and tires. Whats your recommendation. Fyi, stock suspension only.
    Sent from my CPH1723 using Tapatalk
    May 2019
    Quote Originally Posted by MafiaXJX View Post
    Size 16 will more appropriate imo, or else your tires might rub on the fenders when making turns and passing speed humps.
    Jan 2017
    Tire size
    May 2009
    Good day!
    Meron na po ba dito napag change ng CVT fluid for Gen3 Vios?
    Same lang ba process sa non-CVT (e.g. drail/fill)?
    Or may special process that should only be performed in Toyota service center?
    TIA.
    Aug 2018
    Good day guys. Friend of mine has a 2009 vios. His power lock doors aren't working when pressed on the door, and on the keys. The fuses look OK (D/L) and we can hear a clicking noise under the steering column when the switch is being pressed. We can't find the relay. Any ideas?
    May 2019
    Quote Originally Posted by FordGuySRA View Post
    Are all 4 door locks not working?
    Aug 2018
    Quote Originally Posted by Wave24/7 View Post
    Yup all 4 are not working when you use the switch on the door or the key fob buttons. We use the key to open the door and that only unlocks the door you opened, not all 4.
    May 2019
    Sounds like all door lock actuators are out. Test the fuse with a multimeter or switch it with other fuse in the box with the same amp rating and see if the device on that fuse is working.
    Did all of them malfunctioned at the same time or one by one?
    Aug 2018
    Aha so each actuator has a fuse? I'm guessing that's inside each door na? I only tested yung fuse in the fuse box nasa bottom-left ng steering column kasi (which looked OK). He said he's not sure kung sabay sabay because it's an office car which was just permanently assigned to him.
    Jan 2014
    For vios 2016, gano katagal po before magpalit ng coolant?
    And also may naka try na ba ng coolant na TCL ung brand?
    Apr 2014
    Actually, long life coolant na po ang gamit sa Vios or lifetime daw.
    In my case medyo na OC lang ako kaya nag drain and fill lang yun sasakyan after 3 years.
    Advisable po na OEM coolant or Toyota premix coolant ang gamitin para po sa tamang additives na required sa cooling system.
    Sep 2008
    Mga Sir need your advice ulit, galing po ako Toyota kaninang umaga, it seems that my front and rear shocks needs to be replaced after 5 years. 2014 Vios 1.3E po ang unit ko.
    My problem is they quoted me around 24k for the shocks wala pang kasamang labor. I would not tell na lang kung saang Toyota Service center ito basta andito sa Mindanao po.
    Saan kaya pwede bumili ng replacement shock absorber na para sa Vios 2014 1.3E M/T? At anong brand po ba ang maganda?
    TIA at God bless sa inyong lahat.
    Quote Originally Posted by jolam317 View Post
    kyb philippines have the shocks for you. some tire shops can do suspension jobs. they have lifters naman.
    Sep 2008
    Ok po ba ang performance ng KYB when it comes to ride comfort and durability?
    Thanks again at God bless po.
Toyota Vios Owners & Discussions Thread
