View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 372 of 385 FirstFirst ... 272322362368369370371372373374375376382 ... LastLast
Results 7,421 to 7,440 of 11582
    Yep. This was a 2008 Vios J with over 300,000 km. Guy is fine, no injuries whatsoever thankfully.
    He was lucky. He probably rear-ended a PPV at low speed.
    Quote Originally Posted by Woof View Post
    He veered off the road and hit a pole and a wall while travelling at around 40-50 kph.
    Jun 2005
    Is he OK? May tatak toyota sa nuo? Batman J models have airbags?
    The first batman 1.3J models have driver airbags.
    The second iteration have driver and passenger airbags
    Sent from my MI MAX 2 using Tapatalk
    My ahente's Vios just got wrecked after he fell asleep while driving. Nagising nalang siya when he slammed onto his airbag. Buti nalang nakaseatbelt so no injuries.
    the passenger compartment appears intact.
    controlled crush-ability really works.
    Jan 2016
    good eve!
    need help po, naiwan ko kasi yung key remote sa loob ng car and nag auto-lock sya.
    di ko na ngayon mabukasan. nasa akin pa naman yung spare key kaso walang remote yun. natatakot ako buksan kasi baka mag-alarm and hindi ko alam pano i-disarm. baka maistorbo mga kapit bahay kapag nag alarm, gabi na kasi.
    pano po ba i-disarm yung alarm?
    i have the vios 1.3e, 3rd gen. stock alarm lang gamit ko, TVSS.
    thanks po sa tutulong!
    EDIT: nag backread ako,tama ba yung on/off yung accessory para ma disarm?
    Quote Originally Posted by awtz912 View Post
    good eve!
    use your spare key to open the door.
    then, immediately grab the key with alarm remote that you left inside, and press the silence or dis-arm button, to avoid escandalo.
    seriously, po. ganyan lang yan.
    and no, the car won't explode a few seconds after the alarm blares out.
    i don't know with your car, but in some cars, the alarm automatically shuts down, when you open the lock with the key.
    Kulang sa tulog.[emoji42][emoji42][emoji42]
    Jun 2005
    Sa brake caliper ba yan boot na yan? Alam ko repair kit lang yan meron
    Quote Originally Posted by sirkosero View Post
    yun nga eh, sayang naman IIRC nasa 800php din kasi yung buo.
    pero meron akong spare, yun pinaglumaan kaso medyo bloated na yung rubber boot.
    Jun 2005
    Bili ka lang ng local na repair kit kamo. Yung mura lang tapos kunin mo lang yung boot. Ganun ginawa ko dati
    sounds like a plan hehehe
    try ko bro thanks sa tip ..
    i guess heeding dr.d's advice, tignan ko muna quality ng rubber; if not so OK baka orig kit nalang nga siguro.
    isipin mo na lang, na 200 kesos per boot.
    "isang aksidente lang yan, at magsisisi ka dahil hindi mo binili..."
    i know how you feel.
    i used to ford. and ford at that time (80s and 90s), sold only entire assemblies...
    ok pa naman bro, na-OOC lang ako sa bloated rubber hehehe
    Oct 2018
    Hi mga paps,
    Tanong ko lang if pwede ba i-upgrade yung tires from 185/60r15 to 185/65r15 ? Reason is sumasayad kasi yung front bumper sa garahe kapag palabas, need lang ng konting ground clearance... Sakto lang kaya xia at hindi tatama sa fender even fully loaded yung rear ? My car is Gen 2 Vios.
    Thanks !
    Jun 2005
    Quote Originally Posted by Dynamix View Post
    Hi mga paps,
    Thanks !
    Yes. Pwede. Ganyan nakalagay sa gen2 and gen3 ko
    Oct 2018
    Salamat paps !
    Jan 2019
    Question lang po, ano po kaya cause ng ingay sa driver left side ng car? Parang langitngit eh, magpalit na ko ng shock at mounting, ganun pa rin. Vios 2010 po
    Sent from my CLT-L29 using Tapatalk
    Quote Originally Posted by oscarsaplaco View Post
    most fwd have McPherson struts. the lower arm keeps the wheels in place. the bushings on the lower arm gets all the beating. a proper shop can check all of these then there tie rods and ball joints.
    Jul 2010
    2nd gen owners.
    My 2010 Vios 1.3 E MT is at 43k odo.
    Di na nagspray ng tubig yung windshield washer.
    Sira na kaya motor nun? Pag finull ko yung tubig, the next day wala nang laman.
    Quote Originally Posted by noone09 View Post
    2nd gen owners.
    you obviously have a leak.
    that is probably why your washer ain't spraying. there's no water to spray with in your reservoir.
    look for the leak.
    it can be in the reservoir itself, or it can be in the tubings.
    happy searching.
    if your motor or wirings and switch aren't malfunctioning, you can hear the motor run, when you activate the switch.
    look for the leak.
    happy searching.
    patay.. baka nasira na nya pump via cavitation...
    Jul 2010
    look for the leak.
    happy searching.
    Mukhang pump ang sira. I filled the reservoir to the brim then i tried activating the washer. Wala parin lumalabas na tubig.
Toyota Vios Owners & Discussions Thread
