1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Sa mga 2nd gen owners dito sino na nagpalit ng HU na 2 din? Patingin naman. Salamat
^ nope. Walang timing belt ang vios. Chain type sya. Di basta basta pinapalitan
Hi Everyone,
Looks like this thread is more active compared to the Yaris PH one! Questions for a new Yaris owner. :-) I just noticed that the steering wheel does not lock after I take out the ignition key. The SA told me that the model does not have a steering lock. Is that really the case?
Also, the stock battery seems to not be the maintenance-free type. I assume that you need to top up the battery fluid every so often?
Thanks in advance for the feedback!
It will still lock. Remove the key and turn the steering wheel. You will hear or feel a click when it locks.
My other car has a Japanese-brand battery with fluid caps. It still starts strong and I haven't received advice from the casa to top it up after more than a year of use.
Thanks! How far do you have to turn it? In our other cars, assuming that you start with the wheel at the 12 o'clock position, you barely have to reach the 9 or 3 o'clock position before you hear the click. This one, I have gone beyond the 9 and 3 o'clock positions without any clicks.
Possible issue and for warranty claim?
the vios to yaris ratio might be the reason...
if it has battery caps then that's low maintenance, a cheaper one (means big savings to car manufacturers), not necessarily top of of battery fluid every so often but requires "low maintenance" meaning you should inspect it every 3~6 months depending on your usage... (never let it dry as it's a death sentence for the battery)
it does look nice and clean. but i think anyone can do this by just manually cleaning them surfaces and changing the oil a couple of times.
my concern would be, how are the mating surfaces of the metal down below, the parts that we can't see? how does the engine run, po?
10k OCI lang bro and top ups ng fluids lang maintenance per previous owner
So far 3 mechanics and a few officemates have driven it, lahat sila alignment lang reklamo
Conversely, after "repairing" the steering (rack and pinion, joints , bearing etc.), the guy at servitek did not want to do alignment task as it is aligned na daw; he even said the guy who did the repair did an exellent job.
Sent from my E5553 using Tapatalk
Has anyone encountered USB ERROR 4 on their head unit? Di ko pa makapa trigger pero sa 3x na nangyari, yung 2x ay yung naka park ako sa basement ng 8-10 hours, daytime.
Aligned daw bro. Binigyan ko nalang 50 php yun mechanic kasi he gave me some recommendations on what needs changing, like bushing ng joints and others (naka sked na dun sa suki ko)
Btw balance lahat tires except sa isang rear wheel, so had it balanced nalang.
6 liters of coolant 50/50 mix
2 small bottles of brake fluid
2 liters of ATF lll (for ps)
4 liters of mt gear oil
May iba pa ba akong fluid na na-miss? Planning to bleed everything
Done with the coolant and change oil na pala
bakit kaya parang may Clank Clank sound yung vios ko?
palitan na stablink bushing, suspension bushing.
engine support looks OK naman.
feeling ko sa exhaust eh, how will i find out?
have it lifted and then start manipulating the metal things underneath. bring along a rubber hammer, and a tough screwdriver to be used as a wedge against hard-to-move parts.. include the exhaust system. look for loose parts.
in rear-wheel drives, the propeller shaft's universal joints were a favorite source of that clanking sound.
also, if you can manage to produce the clanking sound while an assistant is outside the car, the assistant might be able to narrow down the source some more..
