View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 349 of 385 FirstFirst ... 249299339345346347348349350351352353359 ... LastLast
Results 6,961 to 6,980 of 11582
    Sep 2013
    errr... i can't access the attachment, sir.
    thread follower here.
    Quote Originally Posted by Mask Rider Blac View Post
    Interested here.
    Can't access din.
    Sent from my SM-G7102 using Tapatalk
    resending my PMS file. hope it works...
    Jul 2014
    Quote Originally Posted by kimbon View Post
    Thanks 😊
    Apr 2014
    Not only you but each of us tsikoteer wants to share and help our fellow members to the best of our KSA. Now going back to the coolant issue, I can't find my owner's manual but what I got from my PC file, was the TMPC preventive maintenance checklist (attached herewith) posted by our fellow member way back. If the checklist is still doubtful, I will try look into the forum thread source but it takes a long time to repost. perhaps who ever posted the checklist kindly acknowledge para di na tayo mahirapan mag-dig up sa threads.
    AFAIK TMPC come up that checklist, suitable in MM heavy traffic condition. If you notice item nos 5 in checklist, it says "replace radiator coolant" either 20k, 40k and so forth. It's illogical to replace the coolant when the car mileage reached 100K KM as what you said in your post 10258.
    if you're not still convinced to my post nos 10259 then it's your turn to prove me wrong. The burden of proof is now in your side.
    Attachment 32127
    Heto Sir para makatulong galing sa 2015 Vios manual and sa 2013 Camry manual:
    VIOS
    CAMRY
    Oct 2013
    Quote Originally Posted by midnytwarrior View Post
    VIOS
    CAMRY
    these proves my side, thank you so much
    inspect at every 40,000 KM for contamination, first replace at 160,000 KM then every after 80,000 km, the first checklist provided was when super long life coolant wasn't even used, thus the old checklist should be revised to the new standards...
    save your money and the environment, read the users manual, coolant is not a part of the severe conditions because it is not being contaminated by any other fluid (cooling system is pressurized sealed system) not unless there is a leak...
    Aug 2013
    Ito naman sample job quotation for 80k pms
    *kimbon & Devin miles
    Salamat
    btw pag gusto ko totally drain the coolant, ilan liters need ko to refill? may nagsabi 4, may nagsabi naman 6. salamat
    Aug 2013
    Salamat
    4 liters lang binili ko at may sobra pa. Please my invoice below. 😄 look for "TSLC"
    Quote Originally Posted by Devin miles View Post
    bro is that 2 x 2lit for 319php or just 1 x 2lit?
    Aug 2013
    It's 2 x 2liters (319 x 2 = 638). Hindi ko lang nasama yung total sir.
    Sep 2013
    Thanks to both of you for sharing these infos. Lesson learned...never ever change your coolant when it reached 100k mileage . Case Closed coolant issue kumpanero.
    Salamat
    bro 4 liters ang sa vios. may konting matitira mga kalahating baso ng coolant kapag ibinuhos na ang 2nd container (2 lts) sa radiator.
    if you don't mind tips for draining & refilling the coolant.
    1. flush the radiator with water -when the coolant is totally drained from radiator, flush it with water using garden hose. to make sure only ma-flush out ang kalawang or small debris inside ng radiator.
    2. Coolant Refill- fill up until coolant is visible but a few inches below cap level of the radiator. Start the engine but don't accelerate. the coolant level will lower as the engine sucks in coolant. Continue to fill with coolant until the level stabilizes then install and tighten the cap.
    3. finally, fill up the plastic coolant reservoir with coolant up to max level only. Hwag punuin ng coolant pls. Goodluck bro.
    salamat bro! bagay talaga kayo ni cathy, isang mekaniko at isang detailer ^_^
    Sep 2013
    hehe ang problema bro di nya type ang mekaniko kundi detailer eh. BTW speaking of bagay, may utang ka pa sakin huh. kung sakali di sya pwede may iba ka pa naman di ba?
    Oct 2013
    valve clearance is required to be inspected at 80,000 KM as per users manual, i wonder why casa don't do it (not included in the provided quotation)? no wonder i don't trust then and would rather do it myself...
    Sa mga naka gen2.
    Pa compare naman ng likod ng glove compartment niyo.
    ^Wala ba talagang takip yan? Yan yung nasa taas nung lagayan ng aircon filter..
    Naglinis kasi ako nung isang araw ng filter ko, pag tingin ko may isang ipis pano kaya nangyari yun sabi ko...
    Tapos pansin ko, yan pala yung intake ng hangin pag circulate lang. Tapos may vent yan sa taas na galing naman sa labas.
    Alam ko pinababa at nilinis tong aircon namin...so baka mamaya napitik tong cover na to...
    Aug 2004
    Will check mamya. Mukhang may kulang nga na part dahil may insulating foam around the edge.
    Oct 2013
    Quote Originally Posted by ronki View Post
    Sa mga naka gen2.
    try to move the aircon setting from circulate to fresh air and see that thing move... therefore that is the duct for the fresh air and has no cover for it for its purpose... the main cover you can do is the cabin air filter...
    I followed your suggestion, tama nga hehe. Nag sasara siya pag galing sa labas yung hangin.
    Bali ang intake ng circular motion natin is yung sa paanan ng passenger side.
    Quote Originally Posted by Stigg ma View Post
    bro san banda yung valve clearance? curious ako gusto ko diy din ^_^
    Oct 2013
    page 213 of the second gen user's manual - item# 1
    Jun 2004
    Guys, sorry to post my question here instead of asking in the Yaris section. I just got my 1.5G Yaris and noticed that the LCD Head Unit that Toyota installed is a bit misaligned. It's a bit noticeable since the bottom part is not symmetrical with the bottom panel. Those that have the new Head Unit LCD display, is this common or normal? Or should I have it repaired by Toyota?
    Another thing I noticed is the steering wheel is not centered. Is this normal too or can this easily be fixed?
    Thanks!
Toyota Vios Owners & Discussions Thread
