1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Kulang Lang sa lubrication Ang cv joint kaya may tik tik sound... Hindi naman agad agad nasisira yun... At Pinapalitan ng boot yun sir... Then nilalagyan ng high pressure grease...
️Sir Check mo muna kung biyak na Ang axle boot... If yes.. Maaring ayan na po cause ng tik tik sound...
Hindi bastA bastA nasisira yan... At Ang grasa kasi kumakapit yan... Repack mo Lang... Ok na ulit yan... Ngayon Lang din nya narinig tik tik sound... It means BAGO palang... Pero kung wala naman problema axle boot.. Tapos may tik tik pa din may Tama na nga.. Pero pwedeng Pwede pa Gamitin yun...
Hi mga sir, ask ko lang kung need pa ba lagyan ng water ang engine or di na ksi may coolant na sya?Toyota Vios J 2015 gamit ko.Thanks!
mga sir, tanong ko lang kung anong battery magandang pamalit sa toyota vios second gen?
Visually inspect the coolant level sa reservoir, top up/refill na lang with Toyota Long Life Coolant (yan ang factory coolant nya) kung kailangan. If you use water, mada-dilute lang yung factory fluid at baka ma-lessen ang effectivity nito. And under no circumstance should you use tap water from the faucet.
Di ganun ka-mahal ang isang bote ng Long Life Coolant. Mas mahal magpa-cleaning ng radiator. If your system has no leaks it should last you a long time. Yung bote ko more than two years old na wala pa sa 3/4 ang nagamit.
yung akin mga boss 4 years na ang vios namin never pa ako nag dagdag ng coolant sa nakikita ko hindi sya nababawasan hehehe..
Hello everyone,
I'm relatively new to the forum & want to say first and foremost hello. I have a 2016 Vios and have a lot of questions on my mind right now so I thought I'd start out here with just two questions.
1. Those of you who have 17" TRD Rims, is it worth the money? or would it be better to get Aftermarket rims (Rota, Rays, BBS, Enkei, Vossen) I'm kind of against the wall making this decision.
2. Is there an existing physical group around Baguio city consisting of only Vios owners? I'd like to join if you would have me.
Thanks.
Double Post
mga paps, pa-advise naman, hndi kasi ako makapili, may 2 kasing nagbebenta sakin ng Vios 2006 1st gen(pasensiya na hindi pa afford kumuha ng bnew, dami pang gastos, hehe), yng isa 1.3J(stock lahat), 1.5G(medyo techie set-up) yng isa.. Hindi naman nagkalayo offered price nila. Malaki ba talaga difference nila? Eh Fuel consumption & maintenance nla? TIA mga paps, mabuhay ang Vios.. haha!
Anu pong bulb size ang sukat sa foglight mga sir? Salamat. H11 po ba pwede?
Hi guys,
Need expert advise.. Any idea po about the sound coming out when driving uphill(toktoktok). Ung tipong pag nahirapan ung makina sya lumalbas.. I have this check sa casa 2 weeks ago pero nd nmn nawala bka daw shock ang problem.. Anyone experience this? Tks po in advance.. Vios1.5 user here..
Hi guys.. Update lng, dinala ko sa banaue nong sabado and found out my engine support was broken already, i have it replace for 1300(hindi orig) 5500 kc ung orig.. Mow my car is running smooth.. Tanong ko po bakit kaya nd nakita ng casa un twice ko dinala sa kanila..... Haaaaist..
it's like going to your doctor when you get sick.
he might not nail the bug the first time.. the second time.. but he gets it the third time.
tao lang po lahat tayo.
and to make it seemingly worse... we all have near-perfect hindsight.
