View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 322 of 385 FirstFirst ... 222272312318319320321322323324325326332372 ... LastLast
Results 6,421 to 6,440 of 11582
    Feb 2015
    Quote Originally Posted by Stigg ma View Post
    meron naman dun sa shop, kaso mas mahal nga lang sympre kase negosyo ito, hindi charity...
    Guys baka may gusto NG mags. May binibenta po me mags with tyres na 25k po all in.. Yokohama Adrive r1 195/50r16 mags ko is rota fighter 16x7 almost new fresh na fresh Ito po pictures Call me at 09164640001/09471523199 jericho po contact person
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.jpg
    Jun 2005
    better bring your own. read mo na din procedure from vios club. para masupervise mo gagawa
    madali lang din DIY yan.
    Login
    Jun 2014
    Thanks sa help guys!
    Jun 2014
    Nag palinis na ako ng maf sensor kanina sa motech fairview. Ok naman service nila at friendly staff. Nagpasabay na din ako nagpa break clean at rotate tires. Good thing is ndi na nila na charge un cleaning ng maf sensor. Bigay nalang daw ako tip sa gumawa. So i think nakatipid pa ako. Nakita ko panu tinganggal at nilinis un maf sensor. Madala nga lang gawin. Baklas, spray sa maf sensor, pinatuyo then pinunasan nya pero sa mga gilid lang. After nun kabit na ulit. Takot lang ako mag DIY kc noob ako. Contact cleaner din ginamit pero ndi ko nakita anung brand. Next time bili ako ng mckenic contact cleaner and ako na mag DIY.
    Naglilinis din sila ng throttle body, sayang sa casa pako nagpalinis napamahal pa.
    *sirkesoro - thanks sa pag advice sa motech. Nagpamember na din ako sa kanila for future appointments like pms etc.
    Guys help po.. After i have my aircon cleaned, ayaw n po umilaw ung door sensor ko pag not properly closed.. Vios 97 gen 1..
    Jun 2005
    Quote Originally Posted by jefp0y View Post
    malamamg may tinamaan yan sa may dashboard banda. mali reinstallarion
    wala pang vios nung 1997. gen1 was from 2003-2006/7
    Quote Originally Posted by sirkosero View Post
    6 years pa before the vios came out. baka typo lang ☺
    Jul 2015
    Hi guys! Newbie here. Ang habang back read nito. Haha.
    Jun 2014
    After cleaning the throttle body, my FC changed from 11-12kms to 9.6-9.8kms. Imbis na tumipid, lumakas sa gas..
    Aug 2008
    Quote Originally Posted by _incubus19 View Post
    Mas lumakas kasi ang hatak kaya siguro mas napapasarap sa tapak.
    Jun 2014
    Quote Originally Posted by crave View Post
    Naramdaman ko gumanda hatak. Pero same parin naman driving style ko. Kahit dati bago pinalinis nilalakasan ko din tapak. Pag start kc ng kotse umaabot around 1.8 to 2rpm. Siguru un yung isang reason. Hehe
    Jul 2015
    Hello bossings, newbie ako hehe, kaya magpapatulong sana.
    Vios 2010 ung kotse. Tapos due na for 40k KM PMS. Previously puro casa ang PMS, pero ngayong nagpa quote ako ay nagulat ako sa estimate na binigay ng casa, PHP 21k.
    Tanung ko lang kung ano suggestions niyo, ituloy ko ba or hanap nalang ako ng ibang talyer? Out of warranty na rin kasi so baka hindi na ganun ka-important ung casa PMS.
    Thanks in advance!
    Jun 2014
    Quote Originally Posted by bambomboy View Post
    Thanks in advance!
    Kaya lang umabot ng 21k un cost ng 40k PMS kasi may mga additional yan like engine decarbonizing, undercoating, engine detailing, fuel treatment erc na ndi naman talaga kailangan. Pwede mo naman patanggal un. Mga importante lang pagawa mo like change oil at oil filter, siguru change brake fluids etc. not sure ako sa fluids kasi hindi pako nag 40K PMS. Pero nearing narin ako.
    Apr 2013
    My 40K PMS was estimated around 16 to 17K pesos. After removing all the optional tasks, it went down to 6.6K pesos. Stuffs removed was alignment (since I will be getting new tires and will be needing alignment and balancing), treatment (I had a treatment last 35K), Premium wash (my car was clean inside out), air filter (I bought mine outside and said that I have a replacement waiting at our house), and many miscellaneous things. If you are on the tight budget like me, ask your advisor to remove all the optional maintenance and check your 40K PMS list from the manual. Sobrang laki ng nasave ko... And nagawa rin naman lahat ng required sa 40K, change oil and oil filter, change gear oil, change brake fluids, and check everything. Aircon cleaning will be done pag may budget na ako or pag hindi na comfortable ang lamig (init) sa kotse.
    Thanks in advance!
    May 2012
    Thanks in advance!
    Bro, wala naman problema kung casa or labas ka magpa-pms, basta kailangan lang ikaw ang masusunod sa mga ipapagawa sa sasakyan mo. Research ka lang kung anu-ano yung mga gagawin sa 40k, major PMS yan, dami papalitan like mga fluids kaya mahal. Sa kabila meron dun thread about 40k pms. Try mo bisitahin. Kung comfortable ka sa talyer, sigurado mas mura kaysa casa, basta mapagkakatiwalaan mo yung shop.
    Jan 2014
    Eto 40k pms ko
    imageuploadedbytsikot-forums1437222271.331652.jpgimageuploadedbytsikot-forums1437222292.221993.jpg
    Nasa 8400 total
    Apr 2014
    Quote Originally Posted by luis_ View Post
    Eto 40k pms ko
    Nasa 8400 total
    2 liters lang yun coolant na nilagay?
    Eto 40k pms ko
    Nasa 8400 total
    Jan 2014
    Yes sir. Sobra pa konti sa full. Hinigupan ko pa konti para sumakto sa full. Nasa 60ml binawas ko
    Apr 2014
    So radiator + reservoir lang yun nilagyan nila. Total 2 liters less 60ml so mga 1.4 liters lang.
    So meaning hinde rin coolant replacement, simleng drain and fill lang ng coolant galing lang sa radiator. Pero yun sa loob ng engine hinde nakalabas. Yun new coolant mo contaminated na rin at wala talaga replacement nangyare.
    Jan 2014
    Quote Originally Posted by midnytwarrior View Post
    Paano ba sir tamang replacement? Hindi ko pinanood nung sineservice. 60ml lang sir hindi 600. Gamit ko kasi syringe na 30ml. Naka 2 or 4 ata akong higop bago pumantay sa full line
Toyota Vios Owners & Discussions Thread
