View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 321 of 385 FirstFirst ... 221271311317318319320321322323324325331371 ... LastLast
Results 6,401 to 6,420 of 11582
    ^You can DIY clean your MAF sensor. Tanggalin mo tas sprayan mo lang ng contact cleaner hanggang sa luminis. One of the easiest DIY's hehe.
    Had my clutch replaced recently. Nearing 80k odo. Pwede pa raw sabi ng mekaniko pero malapit na rin bumigay. I recommend na isabay nyo na ang palit ng rear crankshaft oil seal if you'll be replacing your clutch. Yung sa akin daw matigas na sakto lang na pinalitan.
    question mga sir .. bakit iba iba DP ng mga branch ng toyota me mababa me mataas maski puro tfs. bat ganun
    Jun 2014
    Ndi ako marunong magtanggal ng MAF sensor and not sure san sya located. Tingin ko malapit sya sa air filter. Novice ako sa mga ganyan takot ako baka masira ko pa hehe
    Jun 2014
    How much damage ng clutch replacement?
    Jun 2009
    Just installed an OBD II scanner on my unit
    Jun 2009
    Jun 2009
    Nov 2012
    Regarding sa clutch assembly pala same ba din ba yung 1.3cc sa corolla? Binebenta ko kasi yug clutch assembly ko. Original toyota halos bago pa. Hindu kasi ako nakinig sa first owner na kapapalit lang din nya. It turned out timpla ko lang pala haha
    Jun 2014
    Sadly, bumababa ulit sa 500rpm after 2 days. Pero sandali lang unlike before matagal mag stay sa 500rpm. Pero mas ok na ngaun kesa dati. Pretty sure babalik ulit sa mababang rpm pag idle. [emoji17]
    Jan 2014
    Guys anyone already had a ocv problem? Ako yung nag post before na nag cel yung vios ko while driving in the province . Pina check kona siya and it turns out p1656 yung problem which is oil control valve nga daw sabi ko if its neccessary palitan papalitan kona talaga sabi nung mekaniko reset muna daw namin but it if lights again i have to come back and unfortunately nag cel ulit yung car ko while going back here in the province . I just want to ask whats the cause of this problem para ma prevent ko next time kasi medyo mahal magpalit but i had to kaya pag balik ko manila i'll have it replaced
    Oct 2013
    Quote Originally Posted by KrisVios04AT View Post
    normal wear and tear, ang taas ng ng KM reading mo, time na palitan yan...
    Jul 2014
    San ka nakabili ng OBD2?
    Jun 2009
    Jul 2014
    Thanks for the info
    Jun 2014
    After cleaning the throttle body in casa. Napansin ko gumanda hatak ng car. Pero napansin ko din masyado mataas rpm specially when starting the car. Umaabot minsang ng 2rpm. Napansin ko din na bumaba fc ko. Maybe because of not cleaning the maf sensor. Some say madali lang mag DIY ng maf sensor but i'm noob when it comes to this stuff and ayoko masira maf sensor since sabi nila sensitive un hot wires. San pwede mag pa linis ng maf sensor? Any specific auto shop like servitek? Shell? I don't have any suking auto shops. Do i need to bring a contact cleaner to a shop or merun na sila nun? Un area sana around qc from fairview to banawe will do. Salamat sa mga tutulong.
    Jun 2014
    ito pala un nakita ko na contact cleaner sa ace. Not sure kung may lubricant un product. Costs 349php sa ace.
    May 2012
    Quote Originally Posted by _incubus19 View Post
    Ganyan yung ginamit ko nung nag-linis ako maf sensor.
    Jun 2005
    kunin mo yung fast dry na contact cleaner na wwlang lubricant. yung may lubricant kasi attracts more dust. dudumi agad
    about sa shop, try mo sa motech. dati nagpalinis ako dyan but thats about 6 years ago.
    pwede rin yata sa total or petron
    Jun 2014
    Quote Originally Posted by sirkosero View Post
    Thanks for the reply. Un mckenic na electronic contact cleaner fast dry (green bottle). Ndi ko lang na check kung may lubricant. Kailangan ba ako magdala sarili cleaner or merun na sila sa auto shops or gas station?
    Oct 2013
    meron naman dun sa shop, kaso mas mahal nga lang sympre kase negosyo ito, hindi charity...
Toyota Vios Owners & Discussions Thread
