View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 268 of 385 FirstFirst ... 168218258264265266267268269270271272278318368 ... LastLast
Results 5,341 to 5,360 of 11582
    Apr 2010
    Ditto. 2010 Naman sakin parang wala rin hook
    Sent from whatever device I got my hands on via Tapatalk
    May 2012
    Hassle talaga pag walang manual ... can anyone tell me what is the small black button labeled "O/D" on the shifter on my '05 AT? It is right below the big shift button sa cambio.There is also a small black button labeled "Shift Lock" on the console below the cambio? Para saan din ito? same function as the big button?
    Since I can't drive, di ko ma-test... but I just get curious everytime I sit in the front passenger seat.
    Aug 2004
    OD means OverDrive which is your top (in our case 4th) gear. Clicking the switch off forces the tranny (within reason) to downshift increasing the revs for overtaking or climbing or engine braking. You get the same effect by shifting from D to 3 or 2.
    Shift lock unlocks the kambyo from P when the engine is off. Useful for pushing the car short distances without having to start the engine.
    May 2012
    OD means OverDrive which is your top (in our case 4th) gear. Clicking the switch off forces the tranny (within reason) to downshift increasing the revs for overtaking or climbing or engine braking. You get the same effect by shifting from D to 3 or 2...
    Many thanks for your reply. So the O/D button should be engaged/on, by default? And disengaged, when you want to downshift?
    Aug 2004
    Quote Originally Posted by vegetablejoe View Post
    Correct. It should be ON by default. My '95 Lancer had one. Galants of that age also had one. Current transmissions are smart enough to downshift when prodded or floored.
    Bro crave pinatong ko lang nomad ko.
    Yun orig na toyota matting nakakabit pa rin. Di naman dumudulas.
    Sent from my GT-P7310 using Tapatalk 2
    Sep 2013
    share ko lang ang ginawa ko para di dumulas ang matting sa carpet. I bought 3M Velcro with strong adhesive at Ace hardware. I use only the Velcro "hook" as shown picture below and stick this to reverse side of every corner of my matting. Voila! my matings are now fixed...
    Aug 2008
    Napapaisip na nga ako kung itutuloy ko pa ba yung purchase ko eh. Thanks for the feedback bro renzo!
    Quote Originally Posted by kimbon View Post
    Nice idea sir since the velcro hook will add friction to the floor and matting! Will try this first on my universal matting.
    Sent from my SM-N9005 using Tsikot Forums mobile app
    Sep 2013
    Once nakadikit na yung velcro hook sa reverse side ng matting, yung velcro hook na ang didikit sa carpet mo.
    so naka fixed na ito. No friction whatsoever. Make sure to clean using alcohol the reverse side of your matting before sticking the velco.. goodluck sir
    Sep 2013
    Good solution ☺
    Sent from my Nexus 7 using Tsikot Forums mobile app
    Sep 2013
    I was also thinking about the above solution but hesitant. Now that you have tried it I think it must be effective. Was also considering nomad mat.
    Apr 2010
    Good idea! Not only applies on camera / external flash unit but also works on automotive matting. Galing nyo sir!
    FC update, heheheh
    Sent from my GT-I9505 using Tsikot Forums mobile app
    Quote Originally Posted by brainmafia_310 View Post
    FC update, heheheh
    Bro, parang ang baba ng idle mo compare sa akin yan ba normal mo? I would think na it is one factor kaya maganda FC mo.
    Sent from my HTC One X using Tapatalk
    Quote Originally Posted by donskie_0728 View Post
    Yep. Tumataas minsan up to 800 minsan 600 minsan flat out 500 depende sa init ng makina at kung bukas ung ac eh.
    Sep 2013
    pag 500rpm di ba nanginginig ang makina nyo?
    Di naman Sir. Mamaya picturan ko or video pagalis ko magdidinner kasi kami ni wifey eh.
    FC UPDATE: nababanas na ako sa FC ko.
    Sep 2013
    Lubricant saan parte po kaya? Yung ganitong model ba may clutch cable kaya to
    Sent from my GT-I9300 using Tsikot Forums mobile app
    Change oil time. Salamat kay Santa Pajero.
    Sent from my iPhone using Tsikot Car Forums
Toyota Vios Owners & Discussions Thread
