Results 1,421 to 1,430 of 1447
April 12th, 2021 03:43 PM #1421
- Jan 2017
- 29
- Apr 2021
- 3
April 27th, 2021 11:45 AM #1423Ganito din inquiry ko sir, san sa south area may maayos na talyer.
Owner of 2000 revo sr m/t gasoline. Ang nangyari kasi sa akin, ayaw na magregister yung speedometer. Kapapalit lang ng cable, pag ginagalaw yung cable, pumipitik naman yung gauge kaso pag kinabit na, stuck na po sa zero. Nung hindi pa pinapalitan yung cable, stuck yung gauge up until i reach speed of 60.
May mga nahingan na ako ng opinions, sabi nila may papalitan daw sa transmission, kaso ayaw ko ipagalaw yung transmission po neto sa basta bastang talyer lang. May nakaexperience na po ba ng ganitong situation dito?
Sana may mashare kayong talyer na integrity wise eh maayos. Salamat po in advance.
- Dec 2019
- 2,073
April 27th, 2021 12:26 PM #1424Try sa cruiser autoparts sa may sucat near evacom. diyan ako nag pakabit ng speedometer cable ng glx gas m/t ko early last year.
ganyan din issue ko rin dati lagi naman siyan stuck sa 0 yung speedometer needle, tapos pag nasa SLEX na biglang iilaw ang engine light pag natakbo ng mga 80-100kph. nawala naman yung engine light nung pinalitan. pero medyo bouncy na yung speedometer needle pag umaandar na...
- Apr 2021
- 3
April 28th, 2021 01:48 AM #1425
- Apr 2021
- 3
April 28th, 2021 01:52 AM #1426Di naman nailaw yung engine light ko, yung speedometer lang talaga ang di nagalaw even yung numbers sa mileage din na rin nagalaw. Pinagtataka ko lang is after mapalitan ng cable maski high speed di na rin nagalaw.
Sana may parts sila. Puntahan ko yung sinabi niyo. Was thinking sa kasa na kasi baka wala din sila parts na na kailangan kaso mahal dun for sure
April 28th, 2021 02:38 AM #1427
Walang stock atm pero may listing sa lazada nun speedogear baka magkaron ulit ng stocks
Toyota Revo 1.8 7KE,FX 7K Speedometer Gear 33482-29 45 | Lazada PH
- Jan 2017
- 29
June 2nd, 2021 02:41 PM #1428Mga sirs, ok lang ba gumamit ng Toyota ATF T-IV para sa REVO SR? Dexron III (Toyata ATF T-III) kasi ang nakalagay sa manual. Baka may recommended din na magandang replacement brand ng ATF.
salamat
- Jun 2005
- 3,774
June 2nd, 2021 03:03 PM #1429Pwede naman. Afaik T-IV is dex3 equivalent.
Or bili ka na lang dex3 talaga. Mas mura pa sa autosupply.Sent from my MI MAX 2 using Tsikot Forums mobile app
- Jan 2008
- 4,726
June 2nd, 2021 05:59 PM #1430stick to what is the original requirement.. mahirap pag palit palitin lalo na yan ATF ng transmission..
Getting a toyota would be ideal mostly for those looking for practicality or one who will use it...
China cars
