Results 1 to 10 of 308
Threaded View
February 24th, 2010 11:30 AM #37
Yeah, he reproduced the symptoms, but he hasn't said how much he's had to do to reproduce them.
He intentionally short-circuited the car, and used soldered wires and resistor to make a very specific connection between the two accelerator wires. The problem with this is that the resistor makes the ECU see a very specific voltage, which might be impossible to recreate as a failure mode, since short-circuits often create low or high voltage readings from sensors, as well as intermittent and erratic signals, which is what triggers the engine light.
It's like saying he can make an iron catch fire by shorting out the wires leading to the thermostat. Duh. Obviously. The question is, is it realistic to assume that you can get an iron to fail in the same way naturally? Are the wires he's shorting out wires that actually move around and can possibly fray? Or are they relatively far apart? When they short out, will they maintain continuous contact long enough to weld to each other?
Until he releases the schematics and details of how he created this "short", it doesn't mean anything. At least, not yet.Last edited by niky; February 24th, 2010 at 11:34 AM.
if all we are interested in are fuel versus electricity expenses, someone must already have made...
electric powered cars
