Results 261 to 270 of 406
Tsikot Member Rank 4
- 2,716
January 10th, 2009 12:34 PM #261Wind isn't dependable and massive wind farms can be an eye-sore and also kill birds.
UFO strike?
btt - napakaexpensive nyang prius and it doesn't seem to work in the philippines because cars here need airconditioning all the time which messes the fc
- Oct 2008
- 944
January 11th, 2009 03:46 PM #262kung yung honda merong hybrid na murang mura compare sa current prius, baka naman kayang tapatan ng cost cutting ng toyota yung prius nila sa honda
January 11th, 2009 04:32 PM #263
- Oct 2008
- 944
January 13th, 2009 02:34 AM #264hmm never know of that po sir pero yung isa pa i forgot the name hybrid din na nasa us nilang site. kung kaya babaan ng honda hybrids nila siguro naman kaya rin yun ng toyota para sa prius na yan
March 7th, 2009 02:16 AM #265
There are rumors that toyota PRIUS will be out on the local market around June.not yet sure if these are the following specs
Engine 1.5L I4 (4 clylinder 16 valves DOHC)
VAR Speed Automatic Transmission
Hybrid Gas / Electric / Multi-Port Fuel Injected
March 7th, 2009 08:09 AM #267
March 7th, 2009 09:11 AM #268
hybrid engine din ba ang lalabas? may kutob akong mahal pa yan sa altis, pwede nasa gitna ng altis at camry
Tsikot Member Rank 3
- Aug 2003
- 1,251
March 7th, 2009 09:15 AM #269they are really bringing the prius in? Nakita ko ang video nila when someone tested it, one of the reason why they couldnt bring in the prius is the tendency of manila roads to be flooded. And the whole flooring of the car is lined with their battery. Baka mag short pagnabasa. Have they solved this issue?
March 7th, 2009 09:31 AM #270
Toyota don't make engine only Prius so yes it is a Hybrid and I can guarantee you it will be more expensive than the Camry. The one pictured above is the current Prius, meron ng papalabas na all new as a 2010 model w/ 1.8L engine.
2010 Toyota Prius
http://www.motortrend.com/roadtests/...ook/index.html
2010 Honda Insight...much cheaper, about the same price as the USDM Civic.
http://www.motortrend.com/roadtests/...ive/index.htmlLast edited by Camgen6; March 7th, 2009 at 09:45 AM.
high idle RPM at engine start
