Results 1 to 2 of 2
May 5th, 2022 12:10 PM #1
Toyota PH recalls hybrid RAV4, Lexus NX for stability control issue | Autoindustriya
Based on the recall notice (AKA: special service campaign) Toyota Motor Philippines (TMP) submitted to the Department of Trade & Industry (DTI), a total of 132 officially sold vehicles are affected. This consists of 40 units of the NX HEV and 92 examples of the RAV4 HEV. In the global market, the production period of the affected vehicles is from Oct 8, 2019, to April 7, 2022.
The main issue surrounding the recall involves the Skid Control ECU of the vehicle stability control (VSC) found in both the RAV4 and NX. Due to incorrect programming of the software after a particular set of operating inputs from the driver, the VSC may not return to the default 'ON' setting the next time the vehicle is turned off. This can happen if the driver manually turns off the VSC and the ignition is turned off and then turned back on while the brake pedal is still depressed.
June 9th, 2022 03:28 PM #2
Toyota PH recalls LC 300, Lexus LX due to stability control issue | Autoindustriya
TMP will fix the issue affecting LC 300 and LX 600 owners by reprogramming the brake actuator ECU at no cost to customers. Affected customers will only have to bring their vehicles to the nearest Toyota dealership in order to get them checked and/or fixed.
If you recently became the owner of a brand new LC 300 or Lexus LX 600, better head on to your preferred Toyota dealership or at Lexus Manila in Bonifacio Global City (BGC) and have your vehicle checked for the VSC issue.
Having problems with posting images as well.
Problems with viewing Tsikot on non-Chromium...
