Results 1 to 4 of 4
- Oct 2012
- 1
October 10th, 2012 03:40 AM #1Hi Guys,
Bago lng po ako sa forum and need ko lng po humingi ng tulong sa inyo before ako magdecide na ipagawa nanaman yung auto, anyway here's the problems.
1. From 80-100KM/H then full stop for a red stop light nagvivibrate yung manibela k feeling ko parang bumaba masyado yung idling around 700-750RPM, na hindi ko nararamdaman before. (Kapapalit ko lng ng replacement na 2E Carburetor JAPAN and TENSION WIRE AND PLATINUM S.P.) FOR THIS MAY NABASA PO AKO SA NET NA SA DISTRIBUTOR.
2. Then while the car at rest, habang pinapakinggan ko yung makina parang naghihingalo hindi stable yung sound ng makina/carb. It goes high and low
3. Nagflufluctuate yung rpm ko sa Panel Board from 1000RPM then mamaya biglang baba ng 850 parang grounded hindi smooth yung pagbaba ng needle. Then for normal changing dapat ng RPM hindi sakto sa gauge yung pagtapat ng mga needle kapag nagaircon, or headlight (Ano po standard settings ng IDLING AND AIR FUEL MIXTURE sa Carb, or RPM kapag walang aircon, and kapag may aircon and last kapag nakaheadlight) May kinalaman po b ito dun sa wire na inaangat ng mga mekaniko kapag nirereb yung carb? kasi nalost thread yung sa bandang nakaipit sa carb with two nuts.
4. Umuupo/humihinto yung car for 1st gear acceleration pero di na ganun kalakas and katagal before ako magpalit ng CARB na umuupo/humihinto before acceleration sa 1st and 2nd Gear. Anu po yung dapat gawin and dapat palitan.
Maraming salamat po in advance!!
- Jun 2011
- 134
October 11th, 2012 05:14 PM #2700-800 rpm normal idling
900 rpm w/ aircon
Check your a/c idle-up and vacuum hoses.
- Oct 2006
- 1
November 11th, 2012 11:38 AM #3Sir,
similar ang problems natin, 2001 XE unit ko. Although stock form pa yung akin. may mga instances pag 1st gear nagra-rattle ang engine, minsan violently pa. nag-improve sya nung ayusin/adjust ang air ng carb. pero meron pa rin lalo na pag bagong start or pag traffic driving. naayos na ba yung problem nyo? ano ginawa?
November 11th, 2012 03:21 PM #4
Good afternoon Sir,
2E din po makina ko, pwede po ba humingi ng photo or illustration ng vacuum line ng makina nyo, particularly yong linya ng distributor vacuum advance, i want to know po kung saan nakakabit ang mga linyang ito. Below are photos of my distributor vacuum lines traced in green duda po kasi ako sa connections.
Please naman po paki tingnan naman po sa XE ninyo kung saan nakakabit yong dalawang linya,
Somewhat expected from a rushed car from a first time carmaker
Xiaomi E-Car
