Results 481 to 490 of 525
- Jun 2009
- 131
June 26th, 2019 11:50 AM #481ang dami pala magagamit na ATF fluid. haha. nasa 1400 yun malaking ATF, 4 liters ata.
yun Power steering nalang ang kelangan mag canvass.
tuwing kelan pinapalitan yun Radiator coolant? 40k din?
June 26th, 2019 02:42 PM #482
- Jun 2005
- 3,774
June 26th, 2019 08:57 PM #483The old innova uses toyota T-IV. It is cheap when bought by the gallon. Just 1200+ per gallon at toyota makati.
I read toyota T-IV is compatible with dexron3. So you can probably use this for flushing. Just make sure you use toyota T-IV again on the final fill
Sent from my MI MAX 2 using Tapatalk
June 27th, 2019 09:46 AM #484
Yes the T-IV.. I've purchased yung nasa can last 2016 around 400 ata isang can.
Actually yan yung medyo magulo for me kasi may iba akong nakikita na dexron 3 ATF but wala sa compatibility list sa likod yung T-IV.
Yung mga nakita ko lang na alternative is yung Idemitsu and Castrol na may T-IV compatibility sa likod ng bottle.
- Jun 2009
- 131
June 27th, 2019 05:10 PM #485so we called Exalta yesterday and talked to Ruel, sabi 8 liters lang daw ng ATF dalhin namen, so siguro yun nalang bilhin namen then pag kulang yun dun nalang kame bili ng dexron 3 for mumog sa kanila kung meron.
wow hinde na pala kelangan palitan coolant sa radiator, thats nice bawas trabaho. lol.
salamat sa mga reply mga bro's very informative.
o nga pala papalitan ko na din air filter and fuel filter, nakalimutan isabay nung nag change oil.
June 27th, 2019 05:18 PM #486
8 liters not bad na.
Natuto na ako dyan sa coolant kasi nag-drain na din ako niyan walang hiya more than 12 liters pala kailangan takbo agad sa merong aisin pink coolant. 4 liters lang kasi binili ko. Tapos pagbasa ko ng manual 160k kms pa pala due for replacement
Yes sabay na pati cabin filter para swabe takbo kasama aircon
- Jun 2009
- 131
June 28th, 2019 12:11 PM #487hahaha. malaki pala sa AUV. nasanay ako noon sa sedan na isang 2 liters lang solve na tapos yun kulang distilled water nalang and i do it every 2 years. 2nd hand po kasi yun sedan ko noon and the previous owner is just using water, kaya nung nasira yun radiator at na overhaul every 2 years ako nag ddrain at inayos ang thermostat. there are still signs of irreversible damage sa radiator pero no more overheating.
o nga pala... speaking of aircon... pwede po ba ulet mag tanong sa aircon naman.
what is your styles, hayaan masira bago ayusin or pinapalinis niyo evaporator every year? yun blower kasi sa harap mejo mahina na buga, pero wala pa naman ako reklamo sa lamig, not that cold when the car is bnew but still fine. i suspect madumi na yun fan niya mismo, madudukut kaya yun para linisin?
just want to get some PRO tips on aircon.
June 28th, 2019 01:49 PM #488
- Jun 2005
- 3,774
June 28th, 2019 02:20 PM #489
June 28th, 2019 03:04 PM #490
Malaki consumption ng engine coolant kapag diesel engines napansin ko..
For me hayaan nalang masira. Costly din kapag may schedule ka for the replacement ng aircon parts. Usually kapag mahina blower suspect muna dyan yung filter or fan mismo. May iba ako kilala nag-vacuum doon sa part ng butas ng cabin filter.
Yes cheaper kapag by the gallon ang purchase. I think same as gallon vs liter pricing sa engine oils.
Xiaomi E-Car
