tama ka ms. liv. kasi naginspect na ako sa lahat ng lugar....nag mahawakan ko bottle ng armor all...ayun...maaisim nga....
it happend months back na din and ngayon ko na recall na nag armor all nga ako that time....
so, even of armor all for now.
ask ko lng po san hw much is the nomad 3m matting? is it cheaper than the customized one? san po un mura na shop? kc sa marcos hiway, they are charging me 3k for the 3m customized matting.thanks po.
hi all,
help naman po..ano yung adviseable na tire PSI sa innova ko? yokohama tires po yung stack na tires po. Am using 33psi all four. does it mean if lower yung psi mas mabilis mapudpod ang tires? & pag higher psi eh mabilis masira ang shocks?or magkakalampag ang car ko? help ..tnx..
Hi, I m newbie here. I m planning to buy an Innova. It's for my personnal use for work and some deliveries use. Actually, my budget is tight, since car is like a daily necessity for work use.
I m choosing between Innova J variant Diesel Manual or E variant Diesel Manual.
1)What are the major differences between these 2 models?
2) Is the D4D engine problem already solved by Toyota for the 2010 Innova? ( I read thread at " D4D engine problems" that D4D had stalk problems? ).
3) for those Innova J variant Diesel Manual or E variant Diesel Manual user, will the maintenance be expensive?
Hoping your help and comments.
Thanks and more power
http://www.toyota.com.ph/cars/new_ca.../fullspecs.asp Palitan mo lang model from default G to J and E in two browser tabs, tapos ctlr+tab ka lang to swap between the two and note where the text changes.
Just sharing my vvti 10K PMS experience at TMB last Tuesday. The breakdown of the service is as follows:
10K check up P1,064
Ordinary Toyota oil 6Li 987.66
Gasket 28.28
Oil filter 425.60
Spark plugs 364.44
Greases 291.20
Amalie brake cleaner 355.04
Rags 22.40
Sand paper 11.20
Hand gloves 15.68
less: 10% discount on labor -106.40
10% discount on parts -180.60
plus: request to adjust hand brake 448.00
less: 10%discount on labor -44.80
total paid 3,681.69. They finished the job within 2.5 hours. I must say they did a very satisfactory service. Ung concern ko lang eh hindi binalik ang sobrang brake cleaner samantalang ilang sprays lang naman ang ginamit sa fixing. Pansin ko lang mas mabilis ang acceleration using fully synthetic oil noon during 1K pms. Gurus, is the service cost of TMB reasonable? I appreciate your replies.
had my 10k pms, 3weeks ago.
Juris ung adjust hand brake libre un..no charge para dun..
