May experience ba kayo na di nag shift to 4th gear AT gear box?
1st gen VVTI and highway is 9 km/l lang. Napansin ko na hanggang 3rd gear lang going from 0 - 100. Going from D4 to D3 no downshifts din even at highway speeds.
I'll see if makuha sa ATF and filter change. May mga nabasa lang ako from forums abroad for other toyota models na pwedeng cause is faulty ATF temp sensor. Pag di mainit yung ATF e di magshi-shift to 4th gear. Anyone here knows kung anong part number ng ATF temp sensor and kung saan makakabili?
Thanks
Though it is possible that the problem is as simple as you say, a temp sensor, but it's better to have it properly diagnosed first. Validate ATF temp using a diag tool that can read live data. Requires Techstream for that generation Innova because it's not OBD2 compliant.
Nagkaroon ng tagas ng langis yung timing chain/belt cover ng Innova 2013 G Gas ko.. just wanted ask from the group kung magkano magagastos ng pagpa reseal ng timing chain/belt cover? TIA.
