Page 1116 of 1549 FirstFirst ... 101610661106111211131114111511161117111811191120112611661216 ... LastLast
Results 11,151 to 11,160 of 15485
    #11151
    Quote Originally Posted by mike_v1977 View Post
    Mga sirs is it true n pag d4d kelangan muna iwarm up engine for atleast 3 min before lumakad and also same procedure after switching it off pagkatapos or kapg ipapark na? Thanks
    not me.
    i move off a few seconds after my engine starts.
    and i put her off a few seconds after i drive into my garage.
    of course, my house is located several corners from the main road. by the time i get to apply more speed, the engine lubrication will have been fully realized already. and by the time i get home, the engine will already have been running on low, for some time.
    #11152
    The delivery do cost a little higher but I wouldn't go as far as calling it a tourist trap. If I'm not mistaken, they're charging whereabouts of P500 more than the regular cost and they do take credit cards. Maybe consider it as a last resort, in case you get stranded in an empty parking lot at 3AM.
    I've seen those little gadgets but I don't have any experience with them.
    my high school daily allowance was 4 pesos. this is where i'm coming from, when i say "highway robbery".
    Jan 2009
    #11153
    No need to warm up. Just use it immediately after starting. Although, you might want to take it easy until it reaches the operational temp.
    As for cooling down, you might want to do it after a sustained high-speed run. This is to give the turbo time to cool down. It is cooled by the engine oil and the circulation stops when you shut off the engine.
    #11154
    I see, thank u sirs...
    Jan 2009
    #11155
    I know what you mean. But you have to look at it from a perspective of being a premium service.
    May 2012
    #11156
    sir ask ko lang ano usually pinapalitan pa sa innova 2012 E A/T
    ODO reading 28k, 3years kaka change oil lang, break pads, cleaning
    change filters. replace narin battery, buti nalang naramdaman/ at narinig ko iba na pag start
    buti na dead batt ako dito lang sa parking langya hahaha
    ano paba need palitan like brake fluid, ATF, coolant
    at ung pang ilalim hindi ko na alam ang tawag, outside casa ko na kasi gusto pagawa
    salamat
    salamat
    Jan 2009
    #11157
    Quote Originally Posted by evincar View Post
    salamat
    It's really hard to say what needs to be replaced because we don't know the history of your car, how it was driven and what mods you have. For instance, if you have blanked the EGR, this should typically prolong the life of the engine oil so you don't have to replace it as often.
    Around 90% of the maintenance tasks are already documented in the manual. Undocumented tasks (the remaining 10%) may include on-demand or as-needed maintenance. That could include A/C cleaning (rear A/C in particular) especially if it doesn't have a filter, rust inspection and/or rust-proofing, suspension play/rattle, etc.
    #11158
    salamat
    salamat
    if this was your vehicle from brand new, then i suppose the manual lists down a repair or maintenance or replacement schedule. do it.
    but if you bought this vehicle from its previous owner, and you do not know just how faithfully that owner maintained her, ... some will recommend you replace all fluids and consumables..
    salamat
    salamat
    May 2012
    #11159
    salamat sir, yan ang hindi ko na sisilip EGR (exhaust gas recirculation)
    mostly weekend ko lang kasi nagagamit at short trips lang kaya mababa parin ung natakbo
    rust proofing pa check ko rin ilalim
    ty!
    May 2009
    #11160
    just changed the engine oil and filter ng innova ng ate ko at 20k km mark....overdue na nga yung oil (more than 10k km on dino oil). hehehe
    just did it myself. anlayo ng nearest toyota dealer samin. about 5 hrs away. not worth it para paservice pa doon considering the travel time, pagod at gastos sa travel pa lamang. one time dumaan ako para sa change oil nya e andami na nakapila. sabi e baka kinabukasan ko na makuha. kaya bumili na lang ako oil, filter and plug gasket. sabi ng toyota e di naman daw maaapektuhan ang warranty kung ako gumawa (ewan ko lang sa kanila). mistake ko nga nakalimutan ko bumili ng fuel filter.
    ayun, parang mas bumilis ang arangkada after mapalitan ng langis.
    wala lang. just sharing
Toyota Innova Owners & Discussions [continued 3]
