Results 15,041 to 15,050 of 15330
August 20th, 2022 12:22 PM #15041
- 52,731
August 20th, 2022 12:26 PM #15042
- Oct 2013
- 2,537
August 20th, 2022 12:28 PM #15043
- 52,731
August 20th, 2022 12:32 PM #15044the casa is not the one making sayang the crudo; the car owner is, as he's the one paying for it!
i do not doubt the modern-ness of the age.
... but do they do such service, in the casa?
ang alam ko kasi sa casa, they replace. they do not repair.
but i suspect, they do have battery charger, but only to start costumer's dead-battery car, when being claimed by owner.
or maybe jumper wires.
whatever.
bahala na ang owner, when he can't start the car the next day.
errr,
i do not maintain laspag na baterya. i replace it asap, because it's usually a gambling game that i have a large chance of losing in.
but back in the day, when we were students and had very thin wallets, we would persevere with laspag battery syndrome, until we got enough money to buy a new battery.Last edited by dr. d; August 20th, 2022 at 01:00 PM.
- Oct 2018
- 5
September 2nd, 2022 06:26 PM #15045hello may naka experience na po ba nito Click here for video, parang may naiiwan na thin film ng tubig, yung aircon vents di naman po nakatutok sa windshield less than 4 months lang yung wiper blades(Bosch Aerotwin Banana type wipers), need po ba i glass detailing ito or di magandang klase yung nabiling wiper?
September 2nd, 2022 09:03 PM #15046
- 52,731
September 2nd, 2022 09:48 PM #15047it's not a very good view, as only a little bit of the windshield is visible.
but here goes.
i am not sure if that is condensation from outside (happens when it is humid outside, i..e, rain, and it is very cold inside your car because of the aircon).
alas! there is no solution, except to heat your windshield.
you can kill your aircon, but then the condensation will be inside your windshield naman!
turning off the aircon and opening the window will clear up all the condensations, in and out, but i personally also do not want to. not in the rain!
personally, i do not think it is condensation, because condensation is easily wiped off by even a bad wiper blade.
a second possibility is, your windshield is very finely scratched already from wear and tear, or from acid rain. if so, you need a good polishing.
also, it might not be scratched, but it is contaminated with oil or grease. a good washing with soap should clear this up. wash also the blades.
a third possibility, is your wiper blades are worn and need replacement.
lastly, there is a combination of the above.
good luck.Last edited by dr. d; September 2nd, 2022 at 09:50 PM.
September 3rd, 2022 09:24 AM #15048
- Jun 2005
- 3,774
September 3rd, 2022 09:36 AM #15049Design ng innova yan. May plugs sa ilalim ng doors. Problema lang kapag dumumi, nagbabara kay naiipon ang tubig.
Inalis ko na lang lahat ng plugs. My older cars dont have it naman at di kinalawang
Sent from my 2107113SG using Tsikot Forums mobile app
- 52,731
September 3rd, 2022 09:58 AM #15050no car manufacturer wants water to get inside their cars' doors. but to make them truly waterproof, would be prohibitively expensive.
so they do the next best thing: provide drainage.
look at your car, sir, and see if the glass runners and the window rubber are warped.
kung hindi naman... just enjoy your car, keep the drain holes open, and let the drain holes do their job.
so why do car doors' drain holes get clogged?
"dirt."Last edited by dr. d; September 3rd, 2022 at 10:34 AM.
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
high idle RPM at engine start
