Page 1132 of 1549 FirstFirst ... 103210821122112811291130113111321133113411351136114211821232 ... LastLast
Results 11,311 to 11,320 of 15485
    #11311
    ganito din na experience ko few month ago. 5 years old na ang battery. nagkakarroon na rin ng hard starting. pero after replacement ng new battery nawala na ang flickering.
    May 2009
    #11312
    Quote Originally Posted by Migizmark View Post
    Check the connection to crank sensor, if wiring is good and connection is clean then replace the crank sensor and reset the code, this is the first step, the computer could be a problem also but most times its the crankshaft sensor. good day ;-) COmputer reset can be done by disconnecting the battery for at least 5 minutes.... ;-)
    Hi Sir, i'll do this. hindi kasi regular na ginagamit yung inno every weekend lang usually Sunday. Thanks sa advice.
    #11313
    Quote Originally Posted by n5110 View Post
    from the looks of it mukhang battery related pag nag flicker na gauge natin. 5 years na battery mo sir? sulit na yan.. may i know what brand/model sir? mine kasi was stock pa since mag 2 yrs pa lang unit. Every once in a while sa morning kasi sinusukatan ko battery before starting, 12.54 volts naman, then after start panik sya ng 13.62, just to check kung gumagana alternator at nag charge yung battery.
    #11314
    May 2009
    #11315
    may nabanggit si ETCG na acting funny ang dash instruments yung isang sasakyan na inayos nya dahil sa low battery voltage. although different car make iyon. forgot the video title. maaring ganun din siguro sa mga innova.
    #11316
    Quote Originally Posted by tioPAENG View Post
    yung pinalit ko motolite enduro na next bigger size na, pasok naman sa lalagyan.
    #11317
    Sep 2014
    #11318
    good day mga sir! mayroon ba inyo na nagpagawa ng alternator pulley, yung clutch pulley? may long term effect ba kung gawing solid pulley nlng ang alternator pulley?
    Jan 2009
    #11319
    Quote Originally Posted by Kristiano View Post
    Probably not a good idea. You could run into reliability issues. The video shows why decoupling the alternator pulley (non-solid) is important, especially on Diesel engines.
    Alternator pulley comparsion.wmv - YouTube
    May 2009
    #11320
    may one way clutch yang alternator pulley. para maging constant ang output ng alternator. as oj88 stated, baka magkaroon ng reliability issues yang sasakyan mo kapag pinalitan mo ito ng ordinary pulley.
Toyota Innova Owners & Discussions [continued 3]
