Page 1129 of 1549 FirstFirst ... 102910791119112511261127112811291130113111321133113911791229 ... LastLast
Results 11,281 to 11,290 of 15485
    May 2009
    #11281
    Hi guys,
    Been experiencing hard starting after shutting down and restarting it within 2mins. The last time we've experienced this, we've just replaced the battery (the battery shop confirmed that its the culprit). And its almost a year and a couple of mos now after replacing it. The funny thing was when we experience the hardstart we just wait for a few minutes (10-15mins) then its back to normal. Anyone have a fix for this? Any shop you can recommend ? South area or Makati?
    BTW unit is a D4D 2008 Innova. Thanks for the help.
    May 2009
    #11282
    Hi guys,
    Feb 2014
    #11283
    I am not sure if but could be a malfunctioning alternator? Our old corolla exprienced the same thing. Replaced the battery but still hard starting until the alternator was fixed. Maybe its the same with yours. [emoji16]
    May 2009
    #11284
    Quote Originally Posted by Migizmark View Post
    LAST TIME JUST FOR THE CHANGE OIL BOUGHT ORIGINAL FILTER FROM CASA OIL SEMI SYNTHETHIC 10W-30W PhP 3K ++..... front brakes no need to open up only the rear brakes for adjustment of brakes clearance between the pad and brake drum, you can DIY this if you have done it before or ask a mechanic to do it and watch and learn on how to... cleaning the rear brakes assembly, once the brake drum is removed exposing the brake pad lining and the Cylinder/piston assembly,, just hose it down with water and using a paint brush to clean the nook and cranny's then blow dry using a blower no need for the expensive cleaner. if you want to using a 120 grit sandpaper you can rub the brake drum lining ...
    bakit kelangan pa iadjust yung drum brakes e self adjusting na ito via continuous handbrake usage (operation). unless kung nagpalit ng brake shoes.
    #11285
    Hello need your help sa 2012 innova gas ko. Ang lakas nya sa gas ang consumption nya is around 6km per liters mix hiway/city. Hiway is around 7km/ltr. Pinapalitan ko na yung spark plug last week at gumanda na consumption nya to around 10km/ltr pero this week bumalik nanaman sa dating consumption. Ano po kaya ang problema?
    #11286
    Quote Originally Posted by miked View Post
    Sa tingin ko hinde self adjusting ito. Kailangan pa rin buksan at i adjust mechanically sa drum
    #11287
    Quote Originally Posted by jay2 View Post
    Kelan nyo ba napansin yan? Since pag bili ng unit? Kung hinde naman, baka air filter madumi na, gulong malambot hinde mo lang pansin. Yung sa akin second hand 2009 model. Simula ng nakuha ko hanggang ngayon mixed city / highway consistent sa 9 km\li. Gas ito.
    #11288
    #11289
    Bago sir air filter, oil filter at fuel filter. Almost every 5k ang maintenance. But will check again ang gulong nya. San kaya ako pwede mag pa check ng computer sensors nya bukod sa casa?
    #11290
    Yup.. tama si Sir Migizmark.. kelangan pa rin i adjust rear breaks.. everytime nagpa PM ako sa CASA mechanics do that using a flat screw driver to turn the gears nung adjuster sa break piston. just dont remember kung paano ikot nung inadjust... hehe.. How about yung air filter sir Migizmark.. pabugahan ko lang din ba?
Toyota Innova Owners & Discussions [continued 3]
