Page 1182 of 1549 FirstFirst ... 108211321172117811791180118111821183118411851186119212321282 ... LastLast
Results 11,811 to 11,820 of 15485
    Jan 2009
    #11811
    Quote Originally Posted by ParticleX View Post
    Ah ok, pero the diagram I posted on the previous page to install the OCC eh tama ba? Wala kasi ako workshop/engine manual so I could not check. Wala rin pics available online, puro after-install na.
    Plano ko rin to have the EGR blocked, ang pinagiisipan ko lang is kung nakakabit pa rin yun EGR pipe (as in stealth install), dilemma ko lang is baka bumigay yung blanking plates; or totallly remove the pipe na with thicker plates
    The OCC would typically have two ports, an inlet and an outlet. The inlet port connects to the hose that came from the valve cover. The outlet port is then routed to the air intake between the air filter and the turbo.
    I also asked the installer about the possibility of keeping the EGR pipe. He said that doing so may damage the pipe or the nuts/bolts when you tighten it with the blanking panel(s) underneath. His term, hindi na squalado. Hindi lalapat ng maayos yung pipe at baka ma-strip yung bolts.
    May 2005
    #11812
    Just replaced the gear oil and differential oil of our 2005 vvti c/o zix. Super dumi na. Forgot to take pictures
    hi sir, care to share what brand and viscosity (based on the manual?) ? How much per liter?
    sir zix, replaced it for you or you just bought the supplies from him?
    thanks!
    #11813
    thanks!
    Kay zix supplies and labor. Used castrol gl4 and gl5. Used multigrade oils. Sa gas stations usually monograde lang kasi
    Nov 2015
    #11814
    Question po, yun coolant level ko is between low and full , kelangan ko ba sya dagdagan? 43k na tinakbo ngayon ko lang natignan..
    Jan 2009
    #11815
    Quote Originally Posted by Chrisgel View Post
    Technically, that's within acceptable levels. But nothing wrong with topping up. I recommend using Toyota coolant. It's already pre-mixed. I bought a 2-liter jug last PMS to take it with me in the Innova.
    Nov 2015
    #11816
    Ok, should i fill it up to the max level sa reservoir?
    May 2005
    #11817
    Dialysis method ba for the transmission?
    May 2005
    #11818
    Disclaimer, this is for me. I'm not sure if its correct.
    With a cold engine, I fill it up to near the full line. A cold engine is important bec. with a warm engine, the coolant level also rises with it.
    Dec 2007
    #11819
    Up to F or Full level. The extra space is to allow for thermal expansion when coolant reaches operating temp.
    #11820
    this is what i do.
    i check fluid levels when the engine is cold, before i start 'er up in the morning.
    i use the lower mark as the "time to fill up" sign. i use the upper mark as the "fill up to this mark" sign.
    i do this, mebbe once in 2 years...
Toyota Innova Owners & Discussions [continued 3]
