mahal yata for an ordinary oil change. nagpalit ba ng air filter. can you breakdown the cost
Unang estimate nga 5K+
Eto yung details...
6 liters Engine oil --- P881.82
Gasket --- P25.25
Oil FIlter 75*85 --- P380
Spark Plus 4pcs --- P325.4
Grease --- P8.93
Brake Cleaner --- P199.37
Battery Test and Inspection --- P156.25
Tire Rotation with check up --- P267.5
Misc. --- P60.26
Labor --- P950
Thank you very much for the info. & idea. sana ma-tyempuhan ko ulit at makausap ko ung owner ng innova that i saw with the 225/70R15 size na tires. His mags is still the stock mags of G-variant, i just don't know if may spacer nga na nakalagay.
Hi,
New innova owner here. I just acquired my innova G matic Gas this Feb19 Saturday. Pasali din po ako sa club nyo. I'm from laguna.
OK naman ang unit namin. Pero medyo pansin ko lang na masmahina talaga sya sa akyatan compared sa diesel. But everything else is good for now. Sana walang Fuel tank problems itong unit namin.
Based sa ave FC sa MID, around 8km/l ang FC right now. 70%highway 30%city. Sana makuha ko techniques nyo sa patipiran ng gas
Nga pala, ask ko po kung bakit ung tire pressure nung mga tires ay nasa 54? Nabasa ko dito dapat nasa 33 lang sya or lower. Binawasan ko naman sya yesterday to 40. Balak ko sana babaan pa pero parang mukhang malambot na sya. pressure were taken both sa tire gauge ko at sa tire gauge ng gas station. hindi naman nagkakalayo ng reading. so i think hindi naman mali ung reading kasi kinunan ko rin ng reading ung iba kong cars. ok lang kayang ibaba pa to 35? kahit mukhang malambot na ung tires? TIA
i'm using 35psi (nitro)... look flat ng konti sa harap kasi mabigat ang engine![]()
Thanks Sir Wolf at Ma'am Kristine sa reply. Observe mode muna ako. Wala rin nitro dito sa area namin.
I tried using the Petron Turbo Diesel last weekend and meron slight increase in power. Gas pedal is now responsive. I think it also follows that the fuel consumption will suffer. hehe
Hi. In my case I use 33psi kung 2-4person lang but if long trip at puno 33psi sa front then 34 sa likod. You can see also the sticker sa gilid ng driverside, yun nilalapatan ng door, it indicates kung ilang sukat ng hangin kaso not in psi., pero sa shell may conversion yun machine na panghangin.
Those gas boys always tell me to have my tire pressure checked everytime fuel refill because it really looks flat. So I just tell them, "it's filled with nitro". hehe
Good day to all!
Konting katanungan lang po mga innova guru/s, is it ok for the backup sensor switch to be on at all times?minsan kasi nalilimutan..ride is Innova G gas M/T..thanks..
Thanks for the speedy reply sir! mas ok siguro naka on palagi para iwas disgrasya Innova natin!!!good day..
sa akin din parati naka 33psi,may karga man ako o wala,i based it from sa may sticker sa may door,pero ang alam ko if nagpalit ka ng size ng gulong medyo dapat magpalit ka na ng PSI ng gulong (konti difference lang naman)tanung ko lang mga sirs and mam in case am using nitro tapos nagbawas hangin ko puede ko ba haluan ng regular air?
