Page 36 of 91 FirstFirst ... 263233343536373839404686 ... LastLast
Results 701 to 720 of 1815
    Jan 2010
    #701
    Quote Originally Posted by kurtsm View Post
    According to our manual "whatever comes 1st. 3 months or 5Km." Ako I follow the monthly PMS since mababa km reading ko.
    But wont it be a waste of money ? mababa rin km reading ko.. supposedly nov 2010 pa ako magpa PMS but it hasn't reach 5km yet.
    Jan 2010
    #702
    Quote Originally Posted by boomskie View Post
    *Kristine123 - not sure with the gas models pero sa diesel meron.
    *Overlord001 - IMO, waste of cash lang siya. Just follow yung basic rule when driving a turbo-charged vehicle. "Allow the engine to idle for atleast 1 to 2 minutes (especially after driving at high speed for a long period of time) for the turbo to cool down. Do not rev engine before turning it off."
    Quote Originally Posted by kristine123 View Post
    May turbo po ba ang INNOVA natin?
    i think di ko kelangan ito. di naman malayuan ang biyahe ko.
    just to answer your question.
    it cost around 2.5k more or less.
    [SIZE=2]"...[/SIZE]A turbo timer is a device designed to keep an automotive engine running for a pre-specified period of time in order to automatically execute the cool-down period required to prevent premature turbo wear and failure. After a period of driving when a turbocharger has been working hard, it is important to let the engine run at idle speed for a period of time, allowing the compressor assembly to cool from the lower gas temperatures in both the exhaust and intake tracts. At the same time the lubricating oilfrom the engine is able to circulate properly so the turbine won't burn the lubricating oilthat would otherwise be trapped within the charger with the turbine rotating at high speed..."
    [SIZE=4]IF YOU'RE BORED OF READING HERE'S THE SHORTCUT...[/SIZE]
    [SIZE=2]IT ALLOWS YOUR ENGINE TO COOL DOWN GIVING THE PARTS, SPECIALLY THE TURBO, TO BE LUBRICATED PROPERLY BEFORE SHUTTING DOWN. [/SIZE]
    Which scenario would a driver to be qualified to have a turbo timer?
    Jan 2011
    #703
    Quote Originally Posted by Boogie View Post
    Just want to share:
    BPI/MS Insurance Corp
    Coverage: Jan 23 2011- Jan 23 2012
    Net Premium - 15,798.00
    Doc Stamps - 1,975
    Local Govt Tax - 31.60
    EVAT - 1,895.76
    TOTAL ANNUAL PREMIUM DUE - 19,700.36
    PLUS
    - free passenger personal accident (max of 50,000 per person up to 5 incl driver
    - reimbursement of actual towing expense max 1,500 per occurence
    - reimbursement of actual ambulance charges max 5,000 per occurence
    - free express roadside assistance
    OD/Theft - 864,000
    VTPL-PD - 200,000
    VTPL-BI - 200,000
    UPPA - 200,000
    Is this good enough or you had a better offer? My ride is an Innova 2010 E/MT/VVTi.
    Any comments?
    TIA
    2010 Innova E A/T
    Mapfre of toyota makati, w/ AOG...20thou, 5Thou X 4 Months. Hope this helps.
    #704
    Quote Originally Posted by arkisher_13542 View Post
    good day mga ka-innova, tanong lang po san po ba maganda magpakabit ng roofrail and stepboard para sa innova 2011 ang mahal po kasi sa casa toyota dasma....help naman po salamat
    pre, sa tapat ng yazaki emi....sa may imus...dun sa bandang gate 1....dun kmi nagpakabit ng roof rail, spoiler and bull bars....bought our innova j d4d from dasma last december...hth
    Dec 2009
    #705
    A/T po sir?
    Manual po.
    Pa install ko na po sana kahapon grounding kit sa innova ko kaya lang advise saken nung electrician wag na muna daw kasi 1yr pa lang at bago pa unit maganda pa daw grounding connections at wala pang effect sa performance ng car. Effective daw yun sa mga older cars na.
    Oct 2009
    #706
    Quote Originally Posted by wolfhound View Post
    Actually its waste of money talaga but its for the engine maintenance, usually pinagagawa ko lang change oil & oil filter then basic check up, baka kasi na mamaya may mga leaks na lalo sa pang ilalim like shocks at syempre yun preno, yan ang pinakamahalagang macheck kahit na lam nating bago pa unit natin minsan talaga may nangyayari na di natin inaakala!
    yun ride natin, its just like a baby na masyadong sensitive ang needs.
    justmy2cents
    Jan 2010
    #707
    justmy2cents
    Ano po inilagay sa warranty booklet mo? by months na talga?
    Dec 2010
    #708
    Quote Originally Posted by iCeeb0y View Post
    salamat pre, magkano nagastos mo pre? tip naman ng price para di ako mataga...hehe...salamat ulet
    Aug 2010
    #709
    Innova owners,
    gaanong katagal po ninyo hinitay ang units niyo? kumuha po kasi ang lolo ko noong Jan. 20, 2011 (if i'm not mistaken.) nangako po kasi yung dealer na "the following week" pero hanggang ngayon po, we're still waiting.
    TIA
    #710
    mga tol..
    tanong lang,
    tinanggal ko kasi rear tire ko sa driver side.
    i noticed my brake drum is my "square n bakal" nakadikit sa drum.
    check ko sa kabilang side drum wala naman square bakal dun sa kabilang drum,plain lang siya. im thinking bakit hindi magkapareho.
    o baka napalitan itong isang brake drum ko.
    paki check daw ung mga brake drum nyo kung my both "quare bakal" na parang nakadikit.. sa tabi ito ng stud bolt
    hope you maintindihan niyo ako..
    Feb 2009
    #711
    Quote Originally Posted by wakin View Post
    i noticed lately sa innova ko, whenever i turned on the aircon sa harap lang di sya gaano kalamig. pero once i turned on yung aircon sa likod malamig na sya then after a few minutes turn off uli yung aircon sa likod and yung lamig sa harap maintained na. anyone who has the same incident?
    yung suki ko na ac repair shop told me na kapag dual air ang isang car like our innova suggest nya to always open yung ac sa likod naski walang passenger para free flowing daw ang aircon at iwas bara kasi parati daw dapat gamitin,sa tingin nyo does it make sense?
    Dec 2009
    #712
    Quote Originally Posted by vosch View Post
    i always turn my AC in tandem kahit nasa low level lang yung AC sa likod
    Jan 2010
    #713
    Quote Originally Posted by morlack View Post
    mga tol..
    tanong lang,
    i think yan yung parang tingga na kinakabit sa mag wheels to balance it,'
    so same thing din with the brake drum, nilalagyan nila ng counter weight to balance it. just my 2 cents... ngayon kung bakit yung isa meron at yung kabila wala, eh siguro balanced na yung wala....
    #714
    Just got my Innova J 2.5 Diesel from TQA earlier after much deliberation and research. White was my first color of choice but there is no available unit so i had to settle for mica red. I'm really happy with it. Only thing that I noticed was the rattling sound inside the cabin. I think it is coming from the seats. Didn't have time to check it since it's already dark when I took it out from the "stealership".
    Also, they didn't give me a warranty card, the SA told me that it will be given on the 1000kms PMS. Is that true to others as well?
    Any advise for a new owner like me would be highly appreciated. Thank you.
    #715
    Quote Originally Posted by blacksun25 View Post
    kung warranty booklet dapat pagkakuha mo palangn nag oto sa casa meron na...
    #716
    ok.. ganun pala yan..
    So nothing to worry about.
    -bakit hirap tanggalin ang brake drum? ganun ba tagala un. kahit off handbrake..
    but anyway salamat tol..!! pagdating sa innova ko napapraning ako.
    alaga ko kasi..!!
    May 2010
    #717
    dapat pagkuha mo ng oto mo meron na yan! ask mo nga kung bakit ganun sa kanila. sa ibang dealer hindi naman.
    Jan 2010
    #718
    cjsdaddy is right.. Dapat na kuha mo na yung warranty card when you got your car.
    about the rattling shake, i think it's the seatbelt. Clip it on the holder.
    Oct 2009
    #719
    Yes sir by month na, pero minsan kung di talaga gamit ginagawa ko mga 4 months then yun PMS kung inbetween ng 5K example 10K & 15K PMS, pinagagawa ko yun mga dapat I-check both 10K & 15K PMS. Medyo magulo sir, just figure it out. Thanks!
    Jan 2010
    #720
    MAGULO: that's what im afraid at..
Toyota Innova Owners & Discussions [continued 2]
