Results 511 to 520 of 1815
- Feb 2010
- 18
January 14th, 2011 10:49 AM #511Mga Sir Mka pagtanung na rin po about under coat
1. every kailan po ba dapat Mag pa under coat since pagkuha sa Car
2. pag ng pa under coat naka yo dapat pa bang mgpa rust proof
sorry Newbie question
Salamat po
January 14th, 2011 12:42 PM #512
- Jan 2011
- 2
January 14th, 2011 12:46 PM #513mga sir newbie lang po..
tanong ko lang po kung working po ba yung abs? kasi pag switch ko sa on wala lights ng abs.. kahit nagstart na yung engine hinde siya nag lilights..
pinakabitan kasi ng fog lights at alarm. electrical problem kaya yun?
January 14th, 2011 01:47 PM #514
Once you switch the ignition key to "On," the ABS light on the dashboard will come-on and then disappears in a few seconds after it's internal check is complete. Once the car starts moving, you will hear a faint whine within the engine bay telling you that the system is working fine, The sound is from the ABS module "or whatever they call it," near the Fusebox.
The ABS dashboard light remains On when you have a problem in this system. In my case, it happened when my dog chewed on the rear ABS sensor wiring harness.
January 14th, 2011 02:14 PM #515
- Jan 2011
- 35
January 14th, 2011 04:37 PM #516
- Jan 2011
- 35
January 14th, 2011 04:41 PM #517
January 14th, 2011 05:02 PM #518
ideally, dapat brand new pa-rust proofing ka na. pero marami ang hindi nakakagawa nito.
sa amin, sa Ziebart kami nagpa-rust proof. 10k ata bayad namin, kaso lifetime warranty yun against rust.
pero, yearly kailangan mo magpa re-apply and underwash. nasa 600 ata bayad namin yearly. pero sulit.
- Jan 2011
- 35
January 14th, 2011 06:26 PM #519
- Jan 2011
- 2
January 14th, 2011 07:18 PM #520
sir timo07 thanks po sa info..
sinubukan ko po ulet, this time activating and deactivating yung alarm, ok na po sya... pag nilolock ko lang manually without alarm and open using the key, hinde naglilights ung abs.. baka po siguro sa wiring connection ng alarm?
medyo newbie din po ako sa car na may abs...
maraming salamat po for answering my question...
