Results 371 to 380 of 559
- Oct 2012
- 102
January 18th, 2013 11:06 AM #371
February 6th, 2013 09:20 AM #372
- Feb 2013
- 2
February 18th, 2013 07:09 PM #373Guys,
Does the current/latest innova still have this problem? I was pretty much ready to buy but after finding this thread I'm having second thoughts.
February 18th, 2013 07:45 PM #374
- 52,731
February 23rd, 2013 11:41 AM #375if the gas filler cap is the problem, i suggest getting a cheap, replacement cap and drill a very small hole thru it. position the hole so that water does not easily get into it..
i did it once in my older vehicle, and it worked.
and if you change your mind, you can easily use your old, non-adulterated cap again..
February 23rd, 2013 11:55 AM #376
same here it may be the breather.... yung ride ko may filter sa breather... and it was covered with dirt...it is positioned near the rear tires kaya nadudumihan...
baka po nagbabara na yung breather bec. of dirt coming from the tires... maybe we can positioned the breather hose away from the rear tires...
- 52,731
February 23rd, 2013 12:00 PM #377i was wondering about that.. older cars always had a breather tube on their gas tanks, to prevent drastic differences in pressure that can distort the gas tanks, and/or wreak havoc to their carburetors or fuel injection systems... i wasn't sure newer cars still had them... and i'm too old to crawl under cars now to see if there are breather tubes still...
so... porke hindi ko ma-check yung breather tubes, i took the easy way.. drilled a hole thru the cap cover..Last edited by dr. d; February 23rd, 2013 at 12:07 PM.
February 23rd, 2013 04:55 PM #378
- Feb 2013
- 30
February 28th, 2013 10:01 AM #380
high idle RPM at engine start
