Quote Originally Posted by danram View Post
I also encountered this gas tank leak recently but observed coming from a dent under the tank which possibly hit by hard stone or object. I am puzzled only why the leak occurs only between 9-10am & by running the car for about 1 km, the leak stopped....
It was not hit by hard object. If the dent is located near the front strap support and the leak was located at the corner bends in the perimeter of the front strap support, it is the warping syndrome caused by negative pressure when you run the engine, in few more days your leak will get worse. Have your tank repaired immediately and replace the charcoal canister and filler cap. You need to act now or else your car might be part of statistic of burning Innova on the street.
