Results 1 to 10 of 10
    Jul 2015
    I have a Toyota Innova 2003 model J variant (Diesel). May nakainstall na auto lock mechanism yun sasakyan. Just yesterday, gumagana pa yun likod na pinto, nabubuksan ko pa, but today, it won't open anymore, don't know why. If I open from outside if it is unlock, it cannot be open. When I use the key directly at the back, it won't open either, parang ang tigas ipihit kapag ioopen. So I try to open the door from the inside, it seems for this model, parang walang way para buksan from inside yun back door.
    Saan ko kaya pwede ipaayos ito? I am in manila area, hopefully malapit sa lugar ko. Or any suggestions what I can try doing myself. Thank you.
    May 2015
    Quote Originally Posted by konichiwa888 View Post
    Maybe may namuong rust sa key assembly ng pintuan mo. Meron naman sa yt how to disassemble read inner door panel. I think our friend wd-40 can fix that. Hehehe
    Sent from my Redmi Note 5 using Tapatalk
    probably a stuck up mechanism.
    try squirting WD 40 into the keyhole. baka makuha sa ganon (which i doubt).
    the rear hatch siding can be removed from the inside. it's not difficult. hassle lang. you need a very flexible body.
    once removed, you should be able to manually reach into the mechanism.
    hopefully, you can open it manually, then.
    good luck.
    Just saw it now while watching news. Si aga Muhlach and family endorser ng Innova pala. Bagong commercial lang ba ito or matagal na?
    Jun 2005
    Tagal na. Last year pa yata
    Sent from my MI MAX 2 using Tapatalk
    Feb 2005
    Kaya nga kami napabili ni Sirkosero mg Innova dahil kay Aga M. [emoji1787]
    Jan 2009
    I think that the aftermarket lock actuator is stuck. It can be stuck two ways... there's a problem with the lock electronics or it's purely mechanical.
    Try this... Disconnect the battery, wait a few seconds then try to manually unlock it again using the key (battery still disconnected). This is for the off-chance that the lock controller and actuator are trying to 'fight' you. If it still will not budge, then it's definitely a mechanical issue. Try rocking and turning the key in both directions and see if you can free it up.
    Worst case, you will need to enter from the front and pry open the tailgate plastic cover from the inside.
    Buti nga sayo, may key pa. Yung Innova G ko, walang susian sa labas. You're totally dependent on the lock actuator to do its job.
    Jul 2015
    Just to give an update. Naayos na yun back door ng innova ko. Dinala ko sya sa banawe, inayos lng mga 10-15 minutes lng, binuksan nila from inside, and then sabi nila may naloose lng na mechanism, fix lng, kaya labor lng binayaran ko. Thank you.
    that's great!
    fixed na yung lockdown moh!
    yung amin, nag-u-umpisa pa lang.
    Not an Innova, but on the old reliable...the plastic link of the butt barn door handle broke. Nothing some good ol' stitching & resin couldn't fix.[emoji4]
Toyota Innova: Back Door suddenly won't open
