Results 761 to 770 of 2023
March 19th, 2006 09:01 PM #761
This is my observation of a "smoky" 3.0V Fortuner, which I posted in the owner's thread. I think the Fortuner D4-D owners either dont notice it or dont have the problem.
Originally Posted by number001
March 19th, 2006 09:31 PM #762
Dapat di mausok and D4D! What brand , make and model ba car mo ?
Pero try using Biodiesel.
March 19th, 2006 09:37 PM #763
D4D engine should not emit heavy black smoke. Technically if you are saying you have seen it right after idle, possible yun. During idle, emission flow is turbelent in the tailpipe and it creates accumulation of smoke. Also engine could still be cold / not in operating temperature. The moment the driver started the acceleration, smoke in the pipe would be blown out!
Pero, me , i had never seen so far in D4D 2.5 Turbo Matic Innova. My Car is more than a year old. It is also due to the fact that im am also using Biodiesel.
March 20th, 2006 12:56 AM #764
Actually, smoke upon acceleration isn't uncommon with diesels... I've heard it happens with Ford's europena direct injection turbos, too... but for newer generation ones? Any D-Max owners willing to share?
Tsikot Member Rank 3
- Aug 2003
- 1,251
March 21st, 2006 12:08 PM #765larshell, sa mga nabasa ko plus the chemrez seminar offered to tsikot.com, 4x4 group, and kotse.com pipol, a 1% BD application will increase fuel lubricity by 32%. How that works, I forgot the details, but 32% is 32% additional! I believe this is based on a bearing wear test that all lubricant additives use to claim better performance using their product.
March 21st, 2006 06:19 PM #766
Parang gusto kung i-try yong BIODIESEL wd my Innova. How about you are you using BD?
March 21st, 2006 08:02 PM #768
according to toyota ok na daw unit ko, they analyze my unit using "IT2" ??? nothing wrong daw with my fuel pump, ask ko e why nagloloko? sabi ng SA inayos na daw, ang labo nga ng explanation,may reniset daw, ask ko yun ECU ba? hindi naman daw, I'm requesting to provide me the detail of the finding para in case nagloko ulit at dadalhin ko sa ibang dealer at least alam na nila what is the history of my unit e ayaw naman nila mag bigay, sabi ng SA kahit dalhin ko sa ibang casa malalaman agad what my problem is, just using IT2, reason nila is submit daw nila yun reading sa planta, so far ok na , I hope hindi na bumalik yun sakit.
- Sep 2003
- 786
March 21st, 2006 09:13 PM #769Originally Posted by fortuner13
March 21st, 2006 10:57 PM #770
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
