Results 741 to 750 of 2023
- Dec 2005
- 20
March 13th, 2006 03:29 PM #741Originally Posted by larshell
March 16th, 2006 02:06 PM #743
Fortuner13,
Pls. Share naman your Bad experience with Toyota D4d. Thanks
March 16th, 2006 07:28 PM #744
so far, experience hard starting mga 5 times pa lang, mamatay engine pag d inapakan accelerator , dinala ko na sa toyota today kasabay ng 5000 kms check up, ang masama pag dating dun one click andar agadso sabi ng SA test nila ulit pag cold na yun engine, so iniwanan ko na ... sabi ng SA pag observation nila eh kailangan daw may papalitan na spare parts , oorder daw nila sa planta
- Jul 2005
- 499
March 16th, 2006 11:29 PM #745Originally Posted by fortuner13
sana nag gas engine ka na lang para wala kang problema. my odo of my 2.7 vvti in 4 mos is 7k kms, still no problem. thanks again tsikoteers for making me switch to vvti.
- Jun 2005
- 325
March 17th, 2006 10:42 AM #746Originally Posted by fortuner13
March 17th, 2006 11:39 AM #747
maybe because by the time you get to the casa, the injectors and pumps are all "warmed" up or used kaya, pag stop and start gumagana. siguro it needs time to settle down for the problem to reoccur. baka lang
March 17th, 2006 11:57 AM #748
Fortuner13,
Thanks for sharing your experience wd D4d. I hope that Toyota will fix your problem.
Tsikot Member Rank 3
- Aug 2003
- 1,251
March 17th, 2006 12:01 PM #749Originally Posted by jaeger
Given the theory that the spring has lost its resilience due to lack of lubricity, in effect parang may kalawang, you really have to force fuel back into the system (parang wd-40) and revving it up to allow the fuel into each nook and cranny (parang wd-40 din), before it reachieves its resilience and works like its supposed to and thus able to maintain idling levels. IMO lang ito ha. And that's where biodiesel helped in my case. It acts like wd-40, adding extra lubricity, and thus the spring is protected with extra coating, and thus doesn't dry out and loses its resiliency.
March 18th, 2006 08:48 AM #750
altec,
Ano ba ang function ng spring na ito? Bakit kelangan pa i-lubricate? Why is that our unit brandnew and it already have rust? What if you dont use your D4d for a long period of time kakalawangin din ba sya? Spring is located inside the fuel pump right? Why rust accumulate inside the supply pump? If this is the true problem why is that they replace the whole supply pump? Why not replace the spring?
That's what he actually did. He also retrofitted an eps to his 1970s era beetle. Btw, now...
A/c
