Results 641 to 650 of 2023
January 31st, 2006 07:49 PM #641Originally Posted by ReccaH
- May 2004
- 903
February 1st, 2006 09:17 AM #642ako din eh a day after dapat d4d na kukunin namin... good thing nabasa ko... VVTi na lang dahil mahirap kumita ng pera...
February 1st, 2006 11:22 AM #643Originally Posted by lord
Sell it... IMHO.
- Nov 2003
- 71
February 1st, 2006 03:35 PM #644best way to prevent this problem was already mentioned, pick your gas station and in addition, do not let your fuel tank get even close to empty. fill up when you reach 1/4. This is a simple way of preventing that problem becuase if your are close to empty you will be sucking up all the dirt in the bottom of the tank which can cause the d4-d to malfunction and start showing the symptoms you guys have mentioned.
This problem already happened to, I stalled in the middle of slex. A quick remedy is opening the black thing in the engine, remove hose, pump it so the bad diesel will come out, while pumping, have someone starting/cranking the engine. This will work for sometime but problem will probably return, the time you bought will be enough for you to bring it to casa.
These engines are in no way lemons and a recall would be a long shot, IMHO, just do your part and these things can be somewhat prevented.
A few pages back, ask yourself why thailand na lang palagi. I know the answer, but a dead giveaway are our taxes here. I can comment more but maybe not on this thread na lang. Cheers pips!
February 1st, 2006 06:00 PM #645
Wala po sa Fuel or any Gas station ang problema, Meron nga dito 500 ODO reading palang and 10days palang sira na. Fuel or Fuel brand has nothing to do with this problem!
I used only Shell and i have this problem.Lord uses Petron and has this problem.
Innova_Boy Uses Shell and he dont have this problem. Wala po sa fuel ang problema.
Nasa Toyota ang problema kasi hindi nila alam kung ano ang problema.
February 1st, 2006 06:11 PM #646Originally Posted by larshell
February 1st, 2006 06:25 PM #647Originally Posted by Marantz
Selected excerpts quoted from an article in today's Wall Street Journal,
"Thailand-based auto companies build more than 500,000 pickups a year, making the country the world's second-largest truck maker."
"Toyota Motor Corp., which expects to produce 570,000 cars and trucks here (Thailand) this year".
"Ford built 155,000 Ranger trucks at its Thai plant last year, and exported them to more than 130 countries, including destinations in South America."
February 1st, 2006 07:51 PM #648Originally Posted by vicoyski
Is this official? I hope this is official from TMPC. I hope they will also explain this at least to those affected.
February 1st, 2006 08:03 PM #649Originally Posted by m2m
What about the injectors hindi na ba pinalitan?My repair cost is 113t Parts and labor cost is 6t syempre under warranty.
Tsikot Member Rank 3
- Sep 2003
- 786
February 1st, 2006 09:09 PM #650Originally Posted by m2m
high idle RPM at engine start
