Results 1,961 to 1,970 of 2023
- Jun 2008
- 39
November 2nd, 2009 03:47 PM #1961Edi ako swerte din pala... hehehe...
My observation that people in the forums always see the empty part of the glass of water.
I think majority of Toyota D4-D owners are happy with diesel engine. Since aside from this forum. I haven't heard any engine problem on their vehicle.
So for those na nasiraan ng engine malamang sila yun minalas.
I am a proud owner of 2006 Toyota Innova D4-D w/ a mileage of 62,000km and I still recommend Innova D4-D
- Jun 2005
- 155
November 2nd, 2009 03:59 PM #1962
- Nov 2002
- 1,326
November 2nd, 2009 04:03 PM #1963earlier (about a few weeks ago), I posted something here about my Innova D4D having low power problems, at unang diagnostic ng Toyota casa is that injectors ang problem... I went through different tests outside ng casa to find out really what's wrong... and sa huli, I found that the problem is a leak in the exhaust system...
not sure if this is a testimonial for or against the D4D engine... =)
- May 2009
- 406
November 2nd, 2009 08:21 PM #1964
- Nov 2009
- 3
November 17th, 2009 07:13 PM #1965Hello Tsikoteers,
Im also a very satisfied owner of Innova D4D 2007. No engine trouble yet so far. Have driven her to different places in Luzon from Manila to Bicol, Baguio, Tagaytay, La Union and Batangas and used almost daily for city driving with 70K plus odo now.
I also tried to push the engine up to 155 Kph sa NLEX. None of the engine stalling problems or symptoms been encountered yet.
Swerte lang talaga siguro. Goodluck sa mga nagkakaron ng malaking problema.
It goes to show that not all Innova D4D had an engine woe.
November 20th, 2009 02:39 AM #1966
- Jun 2007
- 207
November 20th, 2009 02:33 PM #1967ala n talaga pag asa yan d4d na yan na ma recall ng toyota as long as they are enjoying the sales,dami pa naman bumibili,,,kaya pinaka magandang gawin dyan is magkaroon ng public awareness para ma inform gaano ka bulok un d4d ng toyota at mga casa na walang alam kundi mag change oil,,palibhasa puro ojt tinatanggap para malaki kikitain nila...... kaya binenta ko na lng d4d...
- Jun 2009
- 5
November 30th, 2009 12:55 PM #1968TOYOTA D4D diesel engine is having a major fuel system design flaws or let say making tolerances so close than what is practical to gain more power and efficiency against equal engine but it become very sensitive with fuel purity. Because of its very close tolerances in the fuel system and if the fuel got contaminated it will cause seizure to the fuel pump and them the metal particles will partially obstruct the injector,
then the injector will be having a very bad fuel spray pattern in each cylinder which means different combustion characteristic of every cylinder. When the combustion are different from each cylinder the most possible symptoms are high vibration, loss of power, loud noise and many more. my 2 cent
November 30th, 2009 01:03 PM #1969
we own toyota hilux 2.5 G d4d wala paring problems,, pati power ang lakas!
- Jul 2008
- 13
December 4th, 2009 05:27 PM #1970
high idle RPM at engine start
