Page 503 of 554 FirstFirst ... 403453493499500501502503504505506507513553 ... LastLast
Results 5,021 to 5,030 of 5535
    Aug 2013
    #5021
    Wow. Sakit talaga ng 11th gen aircon
    What year is your car?
    Wait! I'm confused. Is this facelifted 2018 the 11th gen??? Kukuha pa lang sana ako tapos ito mababasa ko. Or baka naman isolated case lang to? Out of 10 ilan kaya may defective aircon??
    Quote Originally Posted by Vann-O View Post
    its a 2011 corolla as per poster. any vehicle at that age meron at meron issues.
    FOCUS
    Jul 2016
    #5023
    Quote Originally Posted by _incubus19 View Post
    Minsan unang bukas palang ng aircon wala ng lamig. Hangin lang. Pag sa traffic hindi naman humihina un lamig. Bigla lang talaga nawawala un lamig tapos hangin lang pero hindi naman araw araw nangyayari.
    99% compressor problem nyan sir.
    Around 28k bili namin dati bnew.. Add mo na labor, cleaning and filter/drier. Ready ka na 35k.
    Clutchless type sya, Ung solenoid ang nagloloko dyan, sya nag aadjust nung compression ratio, ie turning ON and OFF ng compressor.
    Kaya minsan, normal lamig, minsan wala, or minsan hilaw lamig.
    #5024
    Quote Originally Posted by Janemar View Post
    is the solenoid replaceable, or is it hopelessly integrated with the compressor?
    Jun 2014
    #5025
    Ang mahal pala nung culprit ng aircon ko. Nangyari ulit twice nung isang araw. Nakastandby lang ako may inaantay around 30mins. Nawala bigla un lamig, hangin lang. tapos after 15mins naulit ulit na nawala un lamig.
    28k dati? Ilan years ago na un sir? Most likely tumaas na price ngayon. For 10.5 gen pala un akin sir.
    Mar 2018
    #5026
    Possible na bearing lang, although sisirain din eventually compressor. The aircon shop should be abke to tell if your compressor is still okay. Encountered the same problem with a Jazz. Bearing replacement inclusive of labor is 6k. According to the mechanic, they reolaced a lot of those bearings sa vioses as well.
    Sent from my ONEPLUS A3003 using Tapatalk
    Quote Originally Posted by RavenBlack View Post
    yeah baka dry na. kelangan siguro ng lube.
    FOCUS
    Mar 2018
    #5028
    Based on the mechanic's explanation, me sira ang bearing to the point the intermittent ang pag kapit nya sa compressor. I actually check 4 aircon shops, yung isa compressor daw, the other one non commital gusto baklasin muna, the i have a common diagnosis na bearing so I proceeded with the repair. I think the lube (silicon oil) is more applicable sa clutch assemby ng mga radiator fans, which can also cause the same symptoms although mas consistent.
    Jun 2014
    #5029
    Salamat sa mga input sir. At least may idea na ako ano un possible problems sa aircon.
    Jul 2016
    #5030
    Integrated sa compressor as per all the shops we've checked. Didn't bother with the "repair" route since ala na time at baka di rin tumagal...
Toyota Corolla 11th Generation Altis [Merged Threads]
