Results 5,001 to 5,010 of 5476
May 15th, 2018 11:58 PM #5001
Had the car inspected sa reputable aircon mechanic. There was no comment that problem was on the freon. How would I know if the aux fan is the culprit? The altis only has one fan for both radiator and aircon tama po? Umaandar naman po yung fan intermittently.
Anyway, I found this while trying to do some research online. Seems like there is indeed a factory defect on some older units
2 14-2 15 Toyota Corolla Intermittent Poor A/C Cooling at Idle | ToyoSolutions
May 16th, 2018 12:15 AM #5002
If you complained about the AC during warranty period, they can still extend your warranty. Mostly compressor talaga defect. I hope that is not the case with your Altis because that will be expensive.
In my case they also replaced the compressor, condenser, and sensor din ata.
What month did you buy your Altis? If first quarter, parang bad batch ata tayo. My Altis' lock is also defective, 2 pinto pa!
May 16th, 2018 12:24 AM #5003
July 2014. It's part of the first few batch ng altis.
FYI to those having the same issue. It appears the faulty compressors has been acknowledged by Toyota in other countries. Chances our some units here are affected as well. I already emailed TMP about it.
https://www.google.com/url?sa=t&sour...25Ngk5VgB6opeh
Sent from my SM-G930F using Tapatalk
- Aug 2013
- 262
May 21st, 2018 05:51 PM #5004Hi Sirs! Ano po major difference ng G to V (1.6)? Is it worth to buy the V or enough na ung G? Thanks much!
May 21st, 2018 06:24 PM #5005
Not sure sa differences, but all I can say is if you can afford the price difference, go for it. Kung magbabasa ka lang ng listed differences, you might say you can probably forego much of them. But when you have them already, that's when you will appreciate how nice to have these amenities are.
Sent from my LG-H962 using Tapatalk
- 52,810
May 21st, 2018 11:16 PM #5006
- Sep 2006
- 143
May 22nd, 2018 08:19 AM #5007I own the V and i am pretty happy with it. I appreciate the push start capability, auto sensing wipers and headlights also. although not really essential, it is so convenient.
I rarely have passengers at the back kaya di ko masyadong damit yung rolled window shades sa likod. tapos nagpalit ako ng head unit kaya di ko rin nagamit yung mga phone connectivity settings ng radio.
another most used feature is the active sensors sa front and rear.. sa g mas limited ang sensors..
- 52,810
May 22nd, 2018 08:49 AM #5008
- Aug 2013
- 262
May 22nd, 2018 11:06 AM #5009
- Aug 2013
- 262
May 22nd, 2018 11:12 AM #5010
Wheel geometry is more complex than they appear. A lot of factors... steering, suspension,...
Wheel Alignment
