Page 480 of 554 FirstFirst ... 380430470476477478479480481482483484490530 ... LastLast
Results 4,791 to 4,800 of 5535
    Jun 2015
    #4791
    if it can be washed, i'd wash it and save me 5.5K .
    Cabin air filter cost me 900+. 5.5k yung buong 15K PMS. Actually its fine with me if its due na talaga. Im just not sure if its neccessary to replace it that early.
    #4792
    Quote Originally Posted by Sebastian Bach View Post
    if the draft or movement of air is noticeably weaker now, compared to before, then the filter is probably too dirty and has to be replaced (or washed).
    meron yatang replacement filter 'yan, na designed to be washed and re-used?
    #4793
    You don't really need to replace your cabin filter at 15k km unless you travel on dusty provincial roads a lot.
    Check the condition of the current one so you can gauge for yourself how dirty it is. It's in the manual how to remove it - just take out the glove box (fastened by 2 clips) then you should see the filter.
    Dec 2007
    #4794
    My experience with my innova is that I change the Cabin filter myself every 20K km. For the Altis, I'm not as OC as before and have not seen the Cabin filter since I got the car. I was relying on Casa techs doing the cleaning and all. No replacement done on my 20K pm though. Maybe it's time for a visual inspection.....
    Apr 2006
    #4795
    nearing the end of my 3 year warranty. has anybody claimed parts for replacement?
    just had may 35k pms done last saturday. yesterday (sunday), 3 friends decided to ride with me and my wife to an event. i heard a creaking sound on the right back side of the car the moment the 3rd occupant seated. when we arrived at the destination, i heard it again when he stood up to get out of the car. going home, i still heard the sound but this time a different friend occupies the seat.
    only the right side produces the sound. it is usually me and wife who rides the car. rarely do we have passengers at the back. no feedback of suspension problem during the 35k pms. i tried to replicate the problem at home, alone, by bouncing on the back right seat but can't reproduce. is this a symptom of a shock leak? what else should i look at?
    Mar 2007
    #4796
    86 rims on altis? Few questions.
    1. Is 3mm spacer on front would be enough to clear and make space for the calliper? If yes, is it safe to still use the stock stud bold or replace them with longer ones?
    2. For the rear, will the 86 wheels fit in even without adding up spacers?
    Aug 2009
    #4797
    Quote Originally Posted by sp*rk View Post
    Check cushion spring. Been experiencing that also with my Hilux too.
    Jun 2017
    #4798
    Is Replace Air Cabin Filter neccessary for 15K pms? 15k PMS cost me 5.5k with just regular oil. Is this fairly priced? I politely declined all optionals, but I'm not that sure about the air cabin filter.
    I usually refrain from having them replaced sa casa, I do it myself. You'll save a bit that way, madali lang naman yan, bibili ka lang ng air cabin filter sa banawe, you just unclip and remove the old one then replace it with the new one. Super dali lang. Pag sa casa mahal yan almost double ang price. Visual inspection lang pwede na, malalaman mo na if need na palitan pag marumi na talaga.
    K&N filters are washable, although a bit expensive.
    Jun 2015
    #4799
    Quote Originally Posted by jasonbrody View Post
    Yes, nag DIY nalang dapat ako dito. I told the SA to slash off all uneccessary add-ons. But kailangan na daw kasi palitan sa 15K, so um-oo nalang ako. I was not aware na doable pala to on your own. nsa 500-ish lang pala to sa labas at madali lang palitan.
    murahin mo ang SA lol. lesson learnt
Toyota Corolla 11th Generation Altis [Merged Threads]
