Page 299 of 358 FirstFirst ... 199249289295296297298299300301302303309349 ... LastLast
Results 2,981 to 2,990 of 3575
    Jun 2014
    #2981
    when my car's warranty ran out, i started changing oil w/ filter, at the gas station. the petron i go to, has an hecho derecho promo that includes the oil and the oil filter. pasok naman sa spec ang oil nila. less than 1.5K lahat-lahat, and i am done in under an hour. i do not use flush, engine or oil treatment, and even air. just gravity drain.
    that "tok" sounds like CV joint. $$$!
    Less than 1.5k lahat? Ang mura naman nun! Akala ko kasi kahit sa gas station aabutin ka ng 3k sa oil, oil filter at labor. With regards to oil, ano bang recommended viscosity para sa altis?
    San kaya pwede magpacheck ng “tok” sound? Or how much does a cv joint costs? sorry kung madaming tanong. Salamat
    Sep 2017
    #2982
    Mga sir if you don't mind. Ask ko lang po kung may nakapag palagay na sainyo ng V-Kool na tint? Magkano po inabot sa Altis 10th gen natin? Hehe Salamat po!
    #2983
    Quote Originally Posted by chubscaps View Post
    5.5k for OEM series, 6.5k for K-series, 20k for VK series (50% off).
    Sep 2017
    #2984
    Thank you Sir Jut! May idea po kayo if there's any legit seller around South area? Thanks ulit, sir!
    Jun 2014
    #2985
    I am currently using Bridgestone Ecopia 16s worth 4.4K each. Sa Minerva Tyre Gallery ka bumili. Okay dun. Kumho tires are also good, mas mura pa. Kung talagang kulang sa budget, 2 tires muna ang bilhin. Sa harap ilagay ung brand new.
    Ramdam ba un fuel save ng bridgestone ecopia against turanza? Currently bridgestone turanza un nakalagay sa stock ko na 15s. Base sa site ng bridgestone, ecopia can give you up to extra 32kms mileage. I am planning to buy the ecopia since fuel save ang habol ko.
    Jun 2014
    #2986
    Update:
    I have checked my 2 front tires and makapal pa naman but the manufactured date is 2013. I am planning to change 4 tires to bridgestone ecopia with 195/65/15. Base sa owner’s manual, the recommended tire dimension is 195/65/15 which same naman sa current tire ko ngayon na turanza.
    Jun 2017
    #2987
    Quote Originally Posted by _incubus19 View Post
    Update:
    Hi! I totally support you for changing the 4 tires all at once. It's great to have peace of mind. Choose the best used tire -- instead of disposing it, use it as your spare.
    And yes, 195/65 is the size for the G variant (with 15s). I remember that because I was choosing between 1.6 V and 1.6 G more than 8 years ago, hehe.
    Jun 2017
    #2988
    Quote Originally Posted by Ewric View Post
    Ooops, hindi yan, may nag offer sa akin 4.7k fullhd then split screen with parking assistant, ang l,problem is kelangan daw ng drilling, sabi ko pagisipan ko.mukhang heavy duty ehh..
    Yeah... expand your options, then make a short list. I'm also doing that now... but, I might have to say goodbye soon to my Altuy
    Jun 2014
    #2989
    Hi, normal ba na lagi lumalagpas un “arrow” sa FULL pag nagpa full tank? Lagi lang ako automatic. Hindi ko pinapasagad. Un vios at city hindi naman ganun.
    #2990
    mine does.
    it's nothing to be concerned about.
    what we should be concerned about more, is how many km can we still drive, once the needle points to E .
Toyota Corolla 10th Generation Altis Owners [continued]
