Results 2,601 to 2,610 of 3568
November 24th, 2015 10:58 AM #2601
- Aug 2012
- 346
November 24th, 2015 11:08 AM #2602Battery terminals are properly connected and no corrosion or whatsoever, that is the first thing that I've checked. Thanks for the reply by the way, I hope that problem is nothing too serious. I am just worried that it might happen again, worst is it might happen anywhere.
- 52,731
November 24th, 2015 04:42 PM #2603suspect the starter solenoid.
unfortunately, the only way to check it is to bring it down.
if it recurs, you can try push-starting the car (if MT). if it starts, it's the starter system.
- Aug 2012
- 346
November 25th, 2015 09:07 AM #2604I've done some googling and possible causes are MAF, Solenoid starter( just like what dr. d mentioned), and battery. I have my car checked at casa unfortunately the technicians suspected that the cause is the low voltage of the battery, in which I doubt that it is the culprit. Although I must admit that most likely the voltage of the battery is a bit low due to very short distance travel from home to work, 3km more or less, plus the fact that I use it 3x a week max.
Anyways, I just hope it won't happen again. I have been thinking of selling this wherein it seems like its already giving signs....hehehe...Nah...sayang ang pera I am sure this baby can still go a long way and I really love the very comfortable ride of the altis, considering it has only traveled 21K KM in over 4 years.
Thanks for all the reply by the way. Safe driving everybody.
OT: This new POPUP advertisement is very annoying.
November 25th, 2015 09:11 AM #2605
^When i encountered a problem like that, it was a weak battery and it happened to me Christmas eve last year. Could have saved some hassles had i heeded the warning signs. How old is your battery? If it's over two years and you're using the stock batteries that came with the car brand new, it may be time to change.
- Aug 2012
- 346
November 25th, 2015 09:14 AM #2606Thanks Vinj, yeah I think its already 2 years old and it's the 2nd battery since I got my ride. I surely hope that it's just the battery and nothing too serious.
- Aug 2012
- 346
November 25th, 2015 02:26 PM #2607Dami palang possible causes...hehehe...
COMMON CAUSES OF NO-CRANK NO-START
-Low battery (Check battery voltage, recharge if low, or jump start with another vehicle or battery charger).
-Loose or corroded battery cables (Inspect, clean and tighten BOTH ends of BOTH battery cables).
-Bad starter relay wiring connections or ground connection (Inspect, clean, tighten wiring connections).
-Bad starter relay/solenoid (Check for voltage at relay, if relay has voltage but there is no "click" when key is turned to start, replace relay).
-Bad starter (Jump battery voltage direct to starter to see if it spins, or remove starter and have it bench tested at auto parts store).
-Damaged starter drive or teeth on flywheel (Remove starter and inspect drive gear and flywheel teeth, replace damaged parts if necessary).
-Bad ignition switch (Check to see if voltage reaches starter relay/solenoid when turn to start. If not, check for open P/N switch and brake or clutch pedal switch. Replace ignition switch if defective).
-Open P/N safety switch, or open Brake Pedal Safety Switch (automatic transmission) or open Clutch Pedal Switch (manual transmission). Bypass switch with jumper wire to see if engine cranks, or use test light or -voltmeter to check for voltage passing through switch when ignition is turned to start.
-Engine seized due to bearing failure or internal damage (Use socket and long handle to see if engine can be turned by hand, if not engine is locked up).
-Engine hydrolocked due to coolant leak from leaky head gasket (Use socket and wrench to see if engine rotates, remove spark plugs and see if coolant comes out or engine can not be cranked with plugs out).
- Nov 2015
- 23
November 30th, 2015 09:55 PM #2608Hello good evening. Fishing for comments lang sana about a good audio set up? We just bought an Altis 2008 G. Parang I haven't seen any USB Ports or Aux ports. I'd like to connect my phone sana. And kahit papano ma upgrade yung sound quality. I've tried browsing doon sa thread about sound systems pero I don't understand anything kasi since I don't know anything about it yet. If you could give me ideas I'd be very grateful. Thanks.
November 30th, 2015 11:53 PM #2609
- Nov 2015
- 12
December 1st, 2015 01:35 AM #2610
My Ford SYNC just updated itself. Anyone here knows what was updated?
2023 Ford Everest Owners Thread
