Results 1 to 10 of 3575
    Sep 2014
    Quote Originally Posted by 1D4LV View Post
    mukhang medium nga classification ni LTO, kasi i also paid the rate for medium two months ago.... i think it was around 3,600 excluding penalties.
    Hi, I had the same issue so I had my car weighed (2008 1.6G MT) and voila, it only weighs 1,200 KG which is LIGHT. So I had my car registration changed from Medium to Light. You guys should do the same.
    May 2007
    Quote Originally Posted by Mark Labrador View Post
    Tamang tama yung basa ko dito, because i just renewed my registration last week and got surprised na 3500 yung mvuc charge. I bought a second hand 2008 toyota altis last year and now lang ako nag renew. Kaya pala ang mahal. how do you have it changed from medium to light?
    Nov 2007
    Hi, May 2009 ako na Altis. yun dashboard niya parang natutunaw at malagkit pag nabibilad sa araw. sabi nila may recall daw ito. paano mag claim? thanks
    Quote Originally Posted by d_9 View Post
    try to go to a dealer, and ask/take it from there.
    otherwise, wala kang choice except to look for a surplus unit.
    Nov 2011
    Just had my first flat tire a while ago. I was hearing a weird sound (di ko maexplain basta parang hinahangin na part ng koche) before it happened and I thought yun mudcard na loose lang. I just passed by Filinvest exit (I'm from Pacita Complex btw) then yun na, nanginig na yun car and I realized na na flat-an ako. Luckily, walang mashadong sasakyan so I was able to pull over sa shoulder and checked yun gulong. Flat nga! Since madilim sa area na yun I didn't attempt to try changing yun tire dun (haven't tried changing tires before as well) and just drove the car sa nearest gas station which is Shell SLEX - Southbound and asked help sa mga Kuya dun.
    Now, I need a spare tire again kasi mukang may tama din pati yun rim since pinilit kong idrive sa gas station. Any recommendations sirs, preferably south area?
    Mar 2015
    Quote Originally Posted by kiamoyman View Post
    Bridgestone are the best i've tried so far. Toyo brands are also good.When buying make sure you get the latest made one. There's a coded stamp of the date when it was manufactured on every tire. S&R is one good option to buy as they give free balancing including weights,rotation,valves,vulcanizing,nitros during the lifespan of the tires.
    .. you drove all the way to shell? that's quite a distance, for a flat tire.. kaya pala parang sliced doughnut yung gulong..
    that's why, kapag na-flat ang mga puj, dun mismo sa lugar nila ginagawa.. hindi na tinatabi kung minsan.. ayaw nilang masira yung sira-sira nilang gulong o inner tube. "..puede pa yan hanggang sa isang taon.."..
Toyota Corolla 10th Generation Altis Owners [continued]
