Results 991 to 1,000 of 3568
May 29th, 2012 11:17 AM #991
Just last year I went with my friend, nakabili naman kami ng 195/55 R15 tires for 2.5k. Nankang NS-2 nga lang hahaha
May 29th, 2012 12:09 PM #992
How about Michelins kaya for the 16-inchers? 15 months pa lang yung koste sa akin pero parang noticeable na yung wear nung Dunlop stock tires. I'm just comparing with the A-Drives on the FD, mga 18 months na pero parang bago pa din... pareho lang naman sa city ginagamit.
May 29th, 2012 01:02 PM #993
^16 months at how many kms? What's the threadwear rating of the Dunlops? Given that its a sport oriented tire, it should have a softer compound which would wear out faster than the all-around A-drives.
My cousin from the US gave me this neat little digital tire gauge which can also measure tire depth.
May 29th, 2012 02:10 PM #994
*cjv
Panget daw yung Michelin XM1s, yung kaprice range ng A.Drive and LM703.
June 1st, 2012 10:46 PM #995
Hi guys, I'm in need of more ideas. Just got my struts replaced by Toyocars. The problem of stiff suspension("thud" sound) was resolved. Although the squeaking noise(metal to metal) on humps is still there. Tunog umiingit na bakal siya pag dumadaan ng humps, lalo yung mataas. Wala na maisip na problema yung mekaniko dahil napalitan na namin most of the suspension parts (ball joints, stabilizer link, struts). Ano kaya ang posibleng cause nito mga bro? Your opinions would be highly appreciated. Thanks!
- Jun 2010
- 11
June 5th, 2012 09:30 AM #996
i just arrived manila-leyte after getting my altis 1.6v matic at toyota bicutan. FC is 11 kms/liter, traveresed slex, san pablo to bicol and ferry crossing to samar then tacloban. There's nothing more i can say about the altis, engine response is quite good, comfortable to drive...its my first time driving solo for almost 1,000 kilometers with just a brief stopover at camsur
June 5th, 2012 09:37 AM #997
- Jun 2012
- 21
June 7th, 2012 09:25 PM #998Guys,
can you share some insights on the use of the bluetooth handsfree feature of the altis. Does it have voice controls when dialling or answering a call?
June 9th, 2012 12:51 AM #999
Curious question, how does your Altis' accelerator behave? Pagkatapak ba, is it linear in its power delivery?
From what I noticed with ours, from about 0-5% pedal depression, there's virtually nothing there. Then press a little deeper, biglang magrerev to about 2k. Really sensitive through the first quarter of the pedal travel, so it takes a little getting used to. Anyone else have the same experience?
I ask because I read over the Vios thread that it's possible to re-calibrate your accelerator pedal. Has anyone tried this on the Altis? Ano technique? Apparently it varies per car.
June 9th, 2012 01:03 AM #1000
Jut, I guess it's best to try both methods (like sa Vios & FD) para makita mo na rin which of the two will work. Hopefully though, meron.
First try what I did sa Vios. I did it 4x, ON but not the engine. Wait for the dash lights to go off, then press.. Pagabot sa dulo, bitaw. Then off the engine, 5 seconds, ON again but not the engine then do the same for 3x pa
Not sure how many sets is needed for the fd
Sa Vios kasi the difference was noticeable. Sa FD naman I got used to it already so there's no need for me to let the car undergo a relearning process.
high idle RPM at engine start
