Results 3,321 to 3,330 of 3706
- Jun 2012
- 4,447
October 20th, 2015 10:17 PM #3321^ yup you're right. Big points for the rear wheel drive. But for me ertiga is cheaper. Pati sa gas consumption. At mas matagtag kasi ang avanza. And mas nachcheapan ako sa interior (this is subjective). In the end di ka naman talo either of the 2
- Oct 2015
- 3
October 21st, 2015 07:10 PM #3322
- Oct 2015
- 2
October 21st, 2015 09:58 PM #3323Good day,
Naencounter ko n dti un ganyan trouble sa electrical ng 2007 avanza nmn. If confirmed n sabay nawala un tail light at un sa dashboard light? Busted un fuse nyan. Just remove one by one un fuse then visual check if busted un fuse.. My spare n fuse yan dyn sa fuse box at fuse holder pangtangal ng fuse.
- Oct 2015
- 2
October 21st, 2015 09:58 PM #3324Good day,
- Mar 2015
- 34
October 23rd, 2015 12:21 PM #3325Gamitin mo yung puller fuse color white, bunutin mo yung Tail at Stop na fuse baka may busted na dun, malalaman mo pag busted ay putol na sa loob. Minsan din ok ang fuse at bulb sa Tail pero ayaw mag ilaw, pitik pitikin mo lang yung wiring baka nag loose.
Meron din fuse box sa gilid ng manibela, nandun ata yung sa interior lights, check mo na lang dun.
Check mo na din isa isa mga guse bka may busted na, madali lang naman kasi may pang bunot ka naman.
Good Luck
- Mar 2015
- 34
October 23rd, 2015 12:21 PM #3326Gamitin mo yung puller fuse color white, bunutin mo yung Tail at Stop na fuse baka may busted na dun, malalaman mo pag busted ay putol na sa loob. Minsan din ok ang fuse at bulb sa Tail pero ayaw mag ilaw, pitik pitikin mo lang yung wiring baka nag loose.
Good Luck
October 23rd, 2015 03:10 PM #3327
Ang tagal naman lumabas yung 2016 avanza, color gray metallic sa laguna assembly plant. Mga ilang araw pa kaya?
- Mar 2015
- 34
October 23rd, 2015 03:28 PM #3328Sa Indonesia po gawa ang Avanza, hinde sa Laguna. Kya medyo limited pa mga stocks nila.
- Oct 2015
- 3
October 24th, 2015 02:26 AM #3329
- Mar 2015
- 34
October 24th, 2015 08:35 AM #3330Check mo na lang isa isa mga fuse, para makita mo din kung may mga busted na, pati na din yung fuse box malapit sa manibela. Feel free to join sa FB Page ng Avanza Club Pilipinas or sa website na avanzaclub.ph. Marami ka matutunan dun, mababait at matulungin mga member dun.
Had my 2014 Altis repaired by Tireman PH in Gen. Trias, Cavite last Wednesday. Nawala na yun...
rack and pinion repair
